Question about Canon PIXMA MP830 All-In-One InkJet Printer
PIXMA MP830 is Printing Stripes
I ran the cleaning maintenance a few times. Photos print fine. black & white docs are printing in horizontal stripes. Don't know what to do?
  • 286 Answers
Really sounds like the black portion of your print head is clogged. Do the "deep clean" on the black head a couple of times. If it's still not working you may have either a bad head or a clogged purge unit.
Clogged purge units are very common on inkjets.
You can try soaking the bottom of the head on a very wet paper towel overnight. Retry using the head the next day and see if the black is working (print more text documents).
If that doesn't work, you'll have to find a way to check the purge unit/capping assembly under the home position of the head. It will require taking the unit apart and removing the purge unit and cleaning it. Make sure the two tubes are not clogged, Use a piece of wire and feed it through the tubes to try and remove any dried ink.
If you're not into trying to take the unit apart, it's time for a service shop or a replacement printer
Posted on Nov 07, 2008
The print comes out with black printing black and red stripes.
I ran a full clean and maintenance on mine and it worked fine for another month but then it started smudging and putting lines over he paper again. I ended up throwing it and buying a new printer as the Guy at the shop said its worn out. After 4 years of heavy duty printing, it wasnt a bad run.
Sep 16, 2015 | Canon Pixma MP450 All-In-One InkJet...
Black 3e Cartridge
check the printer head and roller inside the printer
also check the nozzle because it may be clogged due to some
dust
Jul 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
My MP600 printer prints horizontal stripes on glossy photo paper. Also, a single line of black dots prints vertically. I have deep cleaned the nozzle and realigned the printing. The wide black cartridge...
First your white horizontal lines are due to you not printing in the best quality. Go into the printing preferences and change the quality to best/quality.
The dots printed vertically are possibly due to ink getting onto the star wheels on the doc exit rollers. Also its possible that the printing media is a bit on the thin side and may need to be supported when exiting the machine.
Those should solve your problem. A new printhead wont make any difference.
Good luck
Jul 10, 2011 | Canon PIXMA MP600 all-In-One InkJet...
My MP830 leaves white horizontal bands when printing black & white documents. Color printing seems fine. Pattern 'F' is missing on the print alignment page.
You need to continually clean and deep clean and realign the black until the results are acceptable. Try manual alignment if the auto does not work. Also clean around the exit hole of the black ink cartidge with a cotton bud and isoproyl alcohol.
Nov 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Stripes printed on every picture
go through your printers software in your start menu and clean the heads.
Aug 21, 2009 | Canon PIXMA MX850 multifunction InkJet...
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
My Canon PIXMA MP760 printer had been printing a horizontal stripe of a lighter cyan where ever that colour occurred. Today during printing it displayed an error. Unfortunately I didn't catch the number. I...
Maybe an obvious answer, but have you cleaned the print heads several times? You can also remove the cartridges, remove the entire print head and clean it with rubbing alcohol and a q-tip.
Mar 28, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Printing in stripes
Possibly time to replace the printer.
Mar 07, 2017 | Canon Pixma MP500 All-In-One InkJet...
Bad quality printing from the black cartridge
Select the correct Media Type setting (Windows)Print an image from another source
Change the Print Quality Settings (Windows)
try these if they dont work time for print head replacement.,
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10236
Nov 30, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Horizontal lines
do a nozzle check, or printer utility check on the printer and see if this helps.
Jun 08, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
455 people viewed this question
old marine
old marine
