Question about Samsung MW1030WA Microwave Oven
Stopped working, Display reads all 8's
My 2yr old microwave was working then just quit. Tried unplugging AC pwr cord and re-plugging and now the display reads all 8's and the only button that will work on the control pad is Handy Helper which goes from On to Off. Other thing is when you try to open the door the oven acts like it is turned on. The light lights inside the box and the fans start turning if you continue to hold the "open door" button in. I have technical background, does it sound like control pad problem? Thanks in advance
  • Steve May Oct 15, 2006
    Thanks for the suggestions. I have tried reseating cable and the only buttons that are active are the Sound and Handy Helper so when I push the 0 button nothing happens.
  • Steve May Nov 21, 2006
    Thanks again for the suggestions, still cannot get any buttons to work except Handy Helper and Sound. I should also point out that when I said the display read all 8's that includes the words above and below the numbers are displayed.
    Does that still sound like a shorted control panel?
  • Samsung Master
  • 9,156 Answers
It sounds like a shorted keypad. This can be due to age/wear or due to moisture. If the unit is sevewral years old or has ben used a lot, then age and wear can be suspected. Moisture is most often due to spraying cleaner directly on the keypad, which allows it to leak into the works. Always spray your cleaner on a soft cloth and then wipe the keypad clean. Moisture can also get in if the microwave is mounted above a stove and a lot of boiling is done without adequate ventilation, usually via the exhaust or hood fan. This fan should be on when cooking on the range top. In some cases, there may be some deposits on the keypad strip where it goes into the connector on the control circuit board. Sometimes that can be cleaned by unplugging then replugging the strip. Could it be that you're not setting the manual according to the instructions in the owner's manual? The manual is olnine at http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf I have attached a scren shot from the manual which shows the clock setting procedure. Maybe it's as simple as this.
Posted on Oct 15, 2006
  • William Miller
    William Miller Oct 15, 2006
    The picture I posted did not present full-sized, so it's useless. Also, the owner's manual URL was cut off.
    Here's the photo:http://207.234.249.73/mwd/samsung_mw_clo...
    And find the owner's manual here:http://tinyurl.com/twhb7
  • William Miller
    William Miller Nov 11, 2006
    I checked the owner's manual and it said to hold down the "0" pad and press the "2" pad to lock or unokck the unit.
    Maybe that works?
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
One day the microwave just showed PF on the screen, unplugged and plugged in tried to use it, worked for 30 seconds, stopped and showed PF again. Any ideas? It is only a few years old and used in our...
PF is Power Failure. Check and see if the Oven has a reset switch or power button. Try and hook up an extension cord, plug one end into a usable output (wall plate) and the other into the 110VA line plug attached to the Oven. Turn on....if it works then the problem is a circuit breaker or wall interface. If it fails with the extension, then it is an electrical problem with the microwave device itself. If there are no Reset features on the oven, an internal fuse may blow, or other shorts are occurring. The cost to fix is more than a new unit. Lowes has them as low as $150.00.
Dec 18, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
My 2001 Kenmore microwave model # 665 6065200 completely quit working today.
It'll be the main fuse on the inside.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Microwave Ovens
Hotpoint microwave only works a few seconds then shows all 8s in the display
Sounds like its time for a new microwave
You can probably buy a new one cheaper then fixing the old one
Most controls that display 888 something is shorted out on the controller.
Have you tried unplugging it for 5 minutes and plugging back in?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 24, 2013 | Hotpoint RVM1435 Microwave Oven
No lights - Acts Like It Has No Power At All
see the diagram and pictorial and proceed with common sense:
1) test the fuse for open or band contact with VOM,see the diagram attached how to do it
2)check the switch door hook or door release button,when they are broken they do not touch the switch, and will NOT start. test for open
see the diagram
Jul 16, 2012 | Microwave Ovens
The touch pad on my GE HVM1540LNICS has stopped working. I tried restarting it by unplugging the cord and plugging it back in, any ideas?
There have been cases where the door switch became defective or knocked out of alignment disabling the key pad, you will need a professional to verify the problem, or someone who is familiar with microwave ovens.
Mar 07, 2011 | GE HVM1540LNCS 950 Watts Microwave Oven
Nothing on my touch pad works
My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
after a few seconds.
We brought it in July or August
Debbie
Mar 27, 2009 | Maytag MMV1153A Microwave Oven
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Samsung MW1030WA Microwave Oven Logo
216 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Simon Flummox
Simon Flummox
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
