Question about Indesit WA 115 Front Load Washer
Indesit w1 13 reset
Program knob clicking round continuosly.machine attempts to start first then the knob just clicks round.does anybody know the reset/reboot procedure.?please??????????
  • shawy35 Mar 01, 2009
    i hav the same prob bet mine is a w103 can any 1 PLEAZ HELP ME
  • Indesit Master
  • 3,463 Answers
If your washer has some black spots on timer dial then set your dial pointer to one of these spots to reset programme.
Then try it again, if it still does the same thing, then you probably have a faulty control module.
Expensive!!!!!
Posted on Nov 18, 2008
You need to empty the drainage plug, at the bottom there is a cover that pulls off, right hand side there is a plug, unscrew it and you will find a hair clip or money remove them and replace the plug put the cover back on an restart your machine
Posted on Nov 16, 2008
Indesit w83 dial just clicks round, is there a reset button some where
Washed any coins lately? I had a front loading washer and when mine did that it was still under warranty so the service came out and pulled a quarter out of the drain trap. If you not sure where that is contact me
Dec 20, 2013 | Indesit W 83
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
Indesit w113 and w1101 wasing machines dial clicking round
This type of fault is usually associated with a faulty programmer. if you have a reset point, then try to reset it, if no reset, then programmer is faulty.
Please rate my solution.
Thanks.
May 11, 2009 | Washing Machines
Indesit W103 On program 7 starts to work then controller just clicks round and round by itself.
I've found you need to reset the program cycle for this. It's annoying to lose the soap and conditioner but generally, if you download the manual and follow the reset instructions (which for me also involved turning the machine off at the mains aswell as holding the power button down with the machine on stop setting) it usually works ok.
Nov 12, 2008 | Washing Machines
Indesit w123s on daily wash program no8 it starts to fill stops and emptys then starts clicking around on the selector knob the only way to reset it is to switch off and leave for a few minutes all the...
you need to open up the small door where the filter is and clear it out. Mine does this everytime my son puts his trousers in the wash and forgets to empty the pockets! we've had all sorts, elastic bands, wrappers, and money. Usually the machine still has water in it as the filter is blocked it won't continue the programme until this is clear and thats why the continuous clicking happens.
B. Green.
Nov 03, 2007 | Indesit WA 115 Front Load Washer
My Indesit won't advance, won't complete a cycle
if the drum rotates at any point and it empties with the pump at any point then check the heater element, its a common fault on these machines
Oct 05, 2007 | Indesit WA 115 Front Load Washer
Suggestion: Try cleaning your outlet filter. This needs periodic cleaning, according to your usage. Refer to user's manual re. the cleaning. When it is the rinse problem it usually is the filter block. W
Oct 05, 2007 | Washing Machines
Broken machine
these machines are a pain. the dial is supposed to click round when there is a fault in a component such as the pump etc but in my experience it is just as likely to be the module. all you can do is to check the pump and heater and whatever else you think you can check and if all ok its the module. not worth repairing in my opinion
Apr 05, 2007 | Indesit W 123 Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Indesit WA 115 Front Load Washer Logo
294 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
