I drop my external hard drive and it still working but my computer did reconised it.I open it and every thing still on place thank you
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
The first thing to try is disconnect and reconnect the USB (?) cable between the drive and workstation.
Shake it 'Gently'. If you hear a sound like metal against metal (disc based drives), the rocker arm is damaged and most likely the drive will need to be replaced.
Posted on Nov 06, 2008
Lacie serial number 1214802236941cr
Try connecting the LaCie to another computer. If this still does not work then the LaCie is faulty.
Nov 20, 2012 | LaCie External USB 2.0 500GB 7200 RPM 500...
My computer does not reconise my verbatim 500 gigabyte external harddrive
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 24, 2011 | Verbatim Corporation Products - External,...
My western digital hard drive doesnt work. it lights up so the power is fine but it doesnt get reconised on the computer or media player. i hav alot of things on it and really need it working again......
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, at a significant discount.
Nov 03, 2010 | Western Digital 500GB My Book Pro-External...
It beeps and computer does not reconise it
Check the warranty-status. If the warranty still is valid, then Hitachi will replace the disk-drive, at minimal cost to you.
If not, then disassemble the enclosure, remove the old disk-drive, buy a new compatible disk-drive, and connect it, to "reconstitute" your external storage-device.
Oct 28, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
I've dropped my Western Digital 250gb hard drive & now its not working. The light on the device does light up & the computer recognises that something has been connected but you cannot see the...
I've similar problem with Samantha_500, i inadvertently dropped internal Harddisk (Seagate 80GB) with external case (M-Tech), the external case was broken into pieces (only the parts with plastic), the Harddisk is not working anymore, it detects by windows XP as a device connected in USB, but no drives detected in windows explorer. is there any way to recover this harddisk? thanks for the help in advance.
Dec 26, 2009 | Western Digital Passport WDXML800UE...
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
I accidentally dropped my 350 GB WD Passport external hard drive and now my computer does not recognize it. Is it still repairable and can i recover the files stored there. Do you have a service center...
Try it another computer.
If it still fails, there are alot of online companies that will be able to retrieve the data for you- although Im guessing the drive its self will be unusable.
Sep 16, 2009 | Western Digital Passport WDXML800UE...
Toshiba external hard drive 1TB USB 2.0
I talked to the customer service of the brand. They know what's related to the noise the HD does right now: real damage. The best thing to do is to switch it off and bring it to a professional data recovery place, which is what I will do next week.
Thank you anyway for your help. I don't need further assistance on this issue.
Cheers,
Dec 15, 2008 | Western Digital My Book Office Edition 1TB...
Dropped hdd beeps wont be reconised by computer
What kind of beep is that? Anything similar to these sounds: http://datacent.com/hard_drive_sounds.php ?
Most likely the spindle got stuck. That's really bad.
Oct 10, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Cannot open hard drive
have you had this drive long if new then go to the control pannel on the mac and find the Amiistrative Tools open then computer managment open then Disk Mangement then open and find the unallcated drive then properties then partition format partition then go to nxt step then follow till end excepting all defaults as hdd is formated for pc not mac so id is needed to be reconised on mac. close all windows then in my computer you should now see hard drive letter if not turn off drive then return on.
Jun 15, 2007 | LaCie USB 2.0 Mobile 60GB 5400rpm 480Mbps...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
