Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
17 in dell monitor
Green light flashes screen blank no noise
  • Anonymous Dec 23, 2008
    gurpreet-"green" colored screen on left and right of my pc screen is coming continously. plz how can i solve it!it's very annoying!!
    gurpreet-"green" colored patches on left and right of my pc screen is coming continously. plz how can i solve it!it's very annoying!!
Hi there.
I have just fixed my monitor. Symptoms were that the monitor would not recover from standby and flashing green power led. I found that the capacitors in the internal power supply had failed. I relaced 2x 100uf/10v Electrolitic capacitors and away we go. Approx $4. Look for swolen or leaky capacitors.
I would say that given the high quality controll these days that the same thing will happen to all these monitors over time. I would recomend replacing all the caps in the power supply.
Posted on May 10, 2009
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Posted on Nov 06, 2008
2 Suggested Answers
  • 27 Answers
SOURCE: i have 17' CRT dell monitor the monitor led light
Double check all your cables are securely attached and if you have pets that no cables have been chewed on. If you can borrow a neighbors monitor do so and you can verify that the problem is your monitor or your computer. Try to just swap the monitor and not the cables to do this test.
All else fails, used 17 " lcd's show up at garage sales pretty cheap ($15-$25)
Posted on Jul 01, 2009
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Screen is blank. Green LED power light is
Might be your graphics card, try swapping it out for a new one and see if that works
Oct 09, 2009 | Dell E173FPb 17" TFT LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell 1702FP 17" Blank Screen Problem
Try it on another computer, if it works the video card moght be dead.
Jul 11, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Dell monitor 173FPb
The flashing is an error code. Call Dell Tech support & they can tell you the exact problem. Hope this helps.
Dec 28, 2008 | Dell E173FPb 17" TFT LCD Monitor
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
SCREEN BLANKS WITH POWER LIT GREEN
Look for bulged or leaking capacitors on the power supply board. If you can solder, you should be able to replace them with the same type and rating and that may just solve the problem. I've had luck with a couple of dozen monitors so far.
Mar 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
519 people viewed this question
Alun Cox
