Question about RCA ViSYS 2-Line Speakerphone
Visys 25204RE1-A can't dial out
We can receive calls, get a dial tone via handset or speaker, but when dialing out, there is no sound of numbers being entered...nothing happens.
  • 2 more comments
  • kluehs Nov 07, 2008
    only have one phone line connected. can receive calls okay. when we try to dial out we do get a dialtone, but the phone will not respond to phone numbers entries
    the interruption of power did not solve problem.touchpad appears to be okay. when phone is in hang up mode, the numeric buttons tone when pressing them. when you select the receiver or speaker, then the numeric buttons are silent when pressed. It's almost as if the unit was programmed to receive only.
    As far as I'm concerned this entire day listening to amateurs address my problem has been a joke. I spoke with a phone and told him what one guy said about a tone capacitor and his comment was "He said what??" Perhaps someone has a 800 number for a RCA tech that can fix this over the without discarding a $95 phone.
    Have already checked the phone line, other phones work fine.-
    Brigadier General:
  • 6,966 Answers
Initially, I would suspect any of three components:
  • DTMF encoder/generator (Dual-tone multi-frequency} (most likely);
  • connector/cable loose connection or a cold solder in the printed backboard (a remote possibility);
  • touchpad/keypad itself (least likely and not all keys will not function).
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
  • 905 Answers
If the phone will not make dial tones when you pick up the handset but will make sounds when the phone is hung up then there is an electronic component problem , and it is most likely a transistor that detects if the switch is hung up or picked up( this is to engage or disengage the key pad , this not a normal function
    Sergeant:
    Champion:
  • 298 Answers
It is most likely the phone cord ,change it... see if that helps it may be just a loose wire.
    Sergeant:
    Novelist:
  • 196 Answers
Replace the cable and check out.it should work .if still the same problem then the phone device must be fauty.check out your phone in some other line and check if its working or not.if not working go for another device.it will work.
thanks.
Posted on Nov 07, 2008
    Top Expert:
  • RCA Master
  • 78,267 Answers
I would try another phone, this will eliminate the connector cord or and the wall jack as the source of the trouble, it may be the phone itself but the line problem is the 1st place to start to figure this issue out.
  • RCA Master
  • 6,487 Answers
Since that is the situation it will be better if you can try to use a different phone so we can check if this is a problem with the unit or with the phone line that you have....
  • 83 Answers
Problem is in your phone faulty reciving tone capacitor u need to change your phone
thks
  • RCA Master
  • 19,396 Answers
If the phone is working, but you cannot hear the tones, then it is probably a setting problem.
To see if this is a setting problem, try unplugging power cord for ten minutes, this should reset the phone.
If the phone does not work, then it is probably a lose or fauty numeric touchpad.
  • 1,879 Answers
That's a 2-Line phone - make sure it is set to dial-out to the correct line.
  • monk3ybidzness
    monk3ybidzness Nov 08, 2008
    outgoing call barring feature on the phone ? cellphone have that.
  • Frank Convert Oct 31, 2011
    I had the exact same problem as stated above. I was remodeling my home office, unplugged my phone and over the course of 2 days - the batteries died. I lost all my memory. I put in new batteries, reprogrammed date/time etc and everything worked accept the keypad. For a full day I could receive calls, speakerphone worked but the only way I could dial out was to use my cordless, dial the number and then switch back to the desktop once the phone began ringing. I knew the phone keypad was not broken because if I pressed the button under the Format Key called 'Dial' - the keypad would work but only when it was on the hook. I was so frustrated that I was about go buy a new phone however I tried one more thing. I unplugged my phone and removed my batteries for about 30 seconds and let the phone reset. I replugged everything back in and voila - it all started working as normal. Go figure but all it needed was resetting. Good luck.
I keep a dial tone, even when I dial a phone number...can't make an outgoing phone...I keep getting the dial tone. can you please help?
1) make sure is the phone is working good
2) there are tone dial
3) see the steps before o.k see ,if there are another phone having the same problem. The problem is service provider.
4) eliminate any background noise., mute the cordless handset before dialing.
God bless you
Sep 26, 2012 | Lands Phones
Constant open line sound from speaker phone
LOL Guessing you have turned BGM (background music) on. Without picking up the handset, press "1". Voila! No music.
Jul 19, 2012 | Panasonic KX-T7433B Corded Phone
Speakerphone doesn't work
Possible. Check out your manual regarding speaker phone settings, etc.
Aug 29, 2017 | RCA ViSYS 2-Line Speakerphone
How do i call
Hello Tedelen,
Be sure to meet all the requirements of the phone to make calls and to be fully operational. These requirements can be found here (Requires Adobe Acrobat Reader).
To make a phone call follow these instructions:
Making calls with the Handset
1. Pick up the handset and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Pick up the handset and press a LINE button to select a line.
2. Wait for a dial tone, then dial a phone number.
3. Hang up the handset when finished.
Making Calls with the Speakerphone
1. Press the SPEAKER button and the phone automatically selects the priority line. If the priority line is occupied, it selects an open line.
OR
Press a LINE button to select a line.
2. Wait for a dial tone then dial a phone number.
3. Press SPEAKER button when finished.
If you are having problems refer to the given link to the User Guide.
-bsalamakha
Jul 05, 2011 | RCA 25415RE3 Phone
Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
Sep 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Have dial tone but can't dial out
I just spoke to RCA and they said to unplug power and phone line and take out batteries, wait 5 minutes and plug everything back in, mine now works.
Apr 23, 2009 | RCA ViSYS 2-Line Speakerphone
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
My voice is not being heard
hi alwayes start chcking a problem from the end and back 1) check the MIC on your handset - connect it to something else and see if it works good... 2) check your output if there is any noise (voltage, other system....) if all is good then the problem is probeply in your COMP: check all audio configurations if that didnt help then its a hardware problem.... good luck
Apr 24, 2006 | Actiontec (DHUSB00020C01)
RCA ViSYS 2-Line Speakerphone Logo
126 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
