Question about HP DeskJet F380 All-In-One Printer
Paper jam Hello, my printer says there is a paper jam when there is not any more as the paper came out, and now it wont let me printything
  • 2 more comments
  • midge95 Feb 10, 2009
    was working fine but then light came on saying paper jam but theres no paper in there, just keeps clonking and banging
    have checked for bits of paper, nothing there, e wont turn off
  • Anonymous Feb 25, 2009
    The printer status shows a paper jam, but there is no paper jam inside the printer.
  • 6west Mar 03, 2009
    tells me there is paper jam which there isn't and also runs the paper right through and out the othe end, just will not print at all and bangs and makes all kinds of noises
    New Friend:
  • 144 Answers
You should check the inside of the printer for litle peaces of paper and turn off e turn on the printer.
Posted on Nov 13, 2008
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Paper concertines up
HELLO WHAT JAI INCLUDING THOSE OF A QUESTION PAPER JAM = if the paper fits in the oven = problem = must clean separation or the ressord that holds fell, puts in place if it is a question of stuffing at the beginning of cycle = ventillet paper i hope that it works for this anomaly
Mar 07, 2012 | Toshiba 1370 Black and White Copier
Tried to copy photo using scanner used photo glossy paper , paper got jammed in printer pulled out paper from front of printer , now printer wont print from computur , help needed .thank you
Hello.
Simply unplug it from the wall for 10 mins, then plug it back in and try again. Sometimes after a jam a re-start is needed.
Regards GM
Aug 01, 2011 | HP Office Equipment & Supplies
Hi, I have hp 1410 printer series and the status says paper jam, however there isnt anymore paper jam, because i pull the paper out already, but still it wont print again and maintains that status, how do...
With the HP printers, paper can get jammed in every tiny little place it can find. Even though you pulled the paper out already, you may have left a small piece in there not realizing it. Open up the printer and if you have a can of "air", spray it throughout the inside of the printer cartridge area. I would also remove the printer cartidge(s) to make sure a piece of paper didn't get in there either. Hope this helps!
Sep 22, 2010 | HP PSC 1410v All-in-One Printer
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
Canon Stylus C64 paper jam
try this link below. Although the printer is lexmark but it can used the idea to solve the problem regarding paper jam issue.
http://www.lexmark.com/publications/pdfs/lexmarkt522/eng/paprjams.pdf
Thanks
Jul 31, 2009 | Epson Stylus C64 InkJet Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
COPIER WONT COPY AS LITE INDICATES PAPER JAM DON'T SEE ANY PAPER AT ALL
Hello sir; Go back to wherever you pull out the paper, because you pull the paper in opposite direction therefor pull off the senser,go back where the paper jam put the senser back in right position.
May 30, 2009 | Sharp AL-1655CS Copier
Paper Jam Error
check the paper feed section of the printer. it may be item stuck in the paper path. causing the paper jam senor to stay on. also it know for these printer to have a waste in full. this will stop all workings of the printer. as these printer only have small waste ink pad in them. Need to know if the printer is flashing just green or if it flashing green led then a orange one.
Sep 23, 2007 | Canon PIXMA iP90 InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
