Question about Garden
Craftsman gas leafblower
After starting and running for a few minutes will stall when putting throttle to max and choke to minimum.
    Scholar:
  • 48 Answers
All small engines take a few minutes to warm up...especially so as they age.
You have to learn to 'feather' the throttle to very, very slowly increase the gas.
After it is warmed up, you are much more likely able to rev it up...release, etc.
I've had many over the years, and this is a very common problem...that you learn how to handle.
Posted on Nov 06, 2008
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
32 cc weedwaker mod#358791072 starts fine, will run at idel for warm up, dies when you give it gas or start it with choke in run position.
If you only have one jet screw adjust the "H" Jet screw on the carb. Make minor adjustments of less than 1/8th turn. Test engine acceleration after each adjustment.
If you have 2 Jet screws "L" and "H" only adjust the "L" screw.
On the 2 jet carb the "H" screw is adjusted for ideal top engine RPM / Max speed.
The goal is to elimate engine hesitation / stall as you grip the throttle quickly by adjusting the "L" jet screw..
Thanks for choosing FixYa,
Kelly
Oct 05, 2010 | Craftsman Garden
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Feb 05, 2010 | Craftsman Garden
Craftsman Weed Eater only runs on choke (not at all now!)
Check the mounting screws holding the carburettor and the plate behiend the carb, they often become loose, also the gaskets, they might need renewing. Your carb. could need cleaning and new diaphrams. stephen.
Sep 20, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Trimmer Runs with choke at idle, then stalls
Sounds like somewhere you have a air leak. Most likely it's somewhere near the carburetor intake or maybe the carb itself. Could be a line from the primer if it has one and i do believe it should that could be leaking or loose. Good luck.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Hey Karl,
To me this sounds like its getting too much fuel after it has been warmed up so either there is too much gas flow to the unit or there is not enough. check your primer bulb once this happens if there is a full bulb when it shuts down chances are its getting too much gas, if its empty then its not getting enough and your fuel filter could be starting to plug up or is not in the tank properly.
Nov 16, 2008 | Garden
Garden Logo
472 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
