Question about Nokia 1100
Re : Battery never last more then three hour
Dear Sir , I have a problem with the Nokia 1100 mobile set . Its network signal is weak and after full charging the battery . It last only three hours in standby mode . After replace the another new battery of the same model . problem are the same . Please advice me what to do and how to find the foult and solve the problem . Thanks K.C.Mandal Nepal
  • K.C. Mandal
    K.C. Mandal Oct 14, 2006
    Dear Sir ,
    Thanks
    K.C.Mandal
    Nepal
Bobo nyo naman!!bigay nlng sakin..
Posted on Oct 03, 2008
Replace the power filer (pf).
Posted on Nov 07, 2006
Replace charging I.C.
Tip
Nokia Mobile Secret Codes
On the main screen type in: *#06# for checking the IMEI (International Mobile Equipment Identity). *#7780# reset to factory settings. *#67705646# This will clear the LCD display(operator logo). *#0000# To view software version. *#2820# Bluetooth device address. *#746025625# Sim clock allowed status. #pw+1234567890+1# Shows if sim have restrictions. *#92702689# - takes you to a secret menu where you may find some of the information below: 1. Displays Serial Number. 2. Displays the Month and Year of Manufacture 3. Displays (if there) the date where the phone was purchased (MMYY) 4. Displays the date of the last repair - if found (0000) 5. Shows life timer of phone (time passes since last start) *#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though. *#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network. *#4720# - Half Rate Codec activation. *#4720* - Half Rate Codec deactivation. The phone will automatically restart If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538# Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345 Press *#3925538# to delete the contents and code of wallet. Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \ *#7328748263373738# resets security code. Default security code is 12345 Change closed caller group (settings >security)
on May 19, 2010 | Nokia 1100
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
Oct 31, 2011 | Nokia Cell Phones
How to unlock memory card password of nokia 3600slide
Sir, I have Nokia 3600 Slide problem occured since last month is it's not swith on/off from the operating button by pluging the chager then it's on the key pad is not working when i press 5 the 8 also come along network problem same sim putting in another mobile gettting network full all the time light blinking that's why charging is weak. Please Sir help in this matter or the confidence of NOKIA will be loosed. I Send Mobile to Nokia Care center they are asking more then it's cost on 20 TH April 2011 help me to sort the problem please response Yes/No .............. Waiting
Dec 04, 2010 | Nokia 3600 slide Cellular Phone
Nokia 1100 shows battery low even after full
your mobile battery is dull check battery first by using another mobile
Jan 18, 2010 | Nokia 1100
Jumper setting
network problem in 1100 nokia mobile please tell me
May 19, 2009 | Nokia Cell Phones
My mobile nokia 1112 s off and I want to know how to cancel I want to know the codes for mobile nokia not have this problem when I have this giant problem
This are the nokia secret tricks:
I have included the trick to restore factory settings and this can reset the whole settings for giant problems.
To check the phones Software revision for Nokia Mobile.
On the main screen type *#0000#
To enter in the secret menu in Nokia Phone.
On the main screen type *#92702689# [*#war0anty#]
It will take you to a secret menu where you may find some of the information below:
To restore Factory Settings for Nokia mobile
Taking picture without getting noticed.
Turn on/off the "click" sound made by the camera by selecting the 'Silent' profile or by turning warning tones on/off.
Hiding your Mobile/ Cellphone Number
Go to: Menu > Tools > Settings > Call > Send My Caller ID >
'Yes', 'No' or 'Set By Network' to follow the default settings of your home network.
It works only with very few network who provide you facility of “Private Number”
Apr 27, 2009 | Nokia 1100
Weak (None) Signal Problem With Nokia N90
ok danish mein ne aap ki problen parkh le hai sab se pehle app apne moblie mein band setting cheak karein. aur ise try band par kar len.ya phir apne cell ki setting restore kar dein agar masnla hal na ho to phir dobara poch le zaror ,thanx
Mar 13, 2008 | Nokia N90 Cellular Phone
Nokia 1100 Logo
81 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
