Question about Biostar M7VKF Motherboard
Panel 1 settings
Hi, I have installed this motherboard but do not have the panel 1 settings powerLED, HDD etc. Can anyone help? The powerLED is a 3-hole connection with hole 1 and 3 positive and negative. The reset, other power and HDD are all 2-hole connectins +and -.
    Scholar:
  • 117 Answers
Hello ocea, Here is a link to the manual: ftp://ftp.biostar-usa.com/manuals/M7VKF/M7VKFmanual.pdf Here is a picture of the front panel settings:
Posted on Oct 14, 2006
Mk40vn no beep no powerled some hdd led some cd led after reset cmos jumper in right position no other jumpers are set on board i have no manual for jumper settings please help me susanne
in some motherboard when you change the c mos jumper the motherboard doesn't switch on change the pin to 1 and 2 normally which is c mos normal and 2 and 3 is to clear c mos you will see marking of all the jumpers in the motherboard set the pin correct to normal and also remove the power connector from the motherboard and short the green and the black wire and see whether the smps works if not working change them
Oct 01, 2011 | Shuttle MK40VN Motherboard
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
Where can i get pyramid-9 PCB No BA41-00167A manual book for setting up power switch,hdd led,reset etc connection setting ???????????
Hello, i was made a search in google, i guess you must look it too, and a don't get nothing, but, I think i've a solution for you, according my own experience, i've installed 2 kinds of different MB, and, althoug there are different brands, the connection pins are the same, ie, the front panel connector that connect HDD Led, Power Led, Reset and Power, is a 9 pin conectors (really have 10, but 1 pin is cut for reference) and commonly is called PANEL 1
Then, i guide you
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Source: My own experience, and check this instalation manual, at 21st Page
http://download.asrock.com/manual/Wolfdale1333-D667%20R2.0.pdf
Jan 07, 2011 | EPoX EP-3PTA Motherboard
Pls help how to install reset led, powerled, hdd led in SiS-74
Find the model name and google it, you should find a manual to help.
Dec 20, 2008 | AMD A7S333 (SiS 745) (MBSA7S333)...
Wiring setup
look for a set of pins ....about 14 of them all together in 2 rows....you need to look on the board around those pins....there should be abreviations eg pwr for power etc.....should indicate where each connector goes.....usually very small writing so make sure you have good light
Dec 16, 2008 | Computers & Internet
PC Not booting up
HI
Please change the smps your cpu and check it..
i'm sure it will work..
Nov 19, 2008 | Computers & Internet
Problem with panel one
The manual is here http://www.pcchips.com.tw/PCCWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=1182&areaid=3&LanID=0 it should have a picture telling you where to plug them in.
Aug 25, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
My computer runs for 2 seconds then shuts down.
First off all download the manual
> Make sure that motherboard is placed correctly
> Front panel connection plugs are there on the manual (4plugs POWERLED,HDD LED,reset switch,power switch) LED plug has positive negative...be careful
May 14, 2008 | Computers & Internet
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
Biostar M7VKF Motherboard Logo
294 people viewed this question
Top Biostar Computers & Internet Experts
Alun Cox
Davit Mamyan
Davit Mamyan
Marvin
Marvin
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
