Question about Kenmore 4292x Front Load Washer
Draining issue After the wash is completed, the clothes are still soaking wet. I have a new drain pump. I have checked all of the drain hoses and the drain trap(no clog). What else can it be? Please help!!!!
  • Anonymous Nov 07, 2008
    I have the same exact problem, and sears replaced my pump in October.
Mine is doing the same thing, and a new pump was put on it last month.
Posted on Nov 07, 2008
My lg washer still has soap in drum when wash is complete
Most like need a new water pump. Do check pump filter housing first.
Feb 18, 2018 | LG Washing Machines
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Maytag mah8700aww clothes wet after cicle
You might need to replace the drain pump. Make sure to listen if you hear the pump kicking in
Jul 25, 2012 | Maytag Washing Machines
My HE2 front loader has a problem draining. It will be "locked" after washing. It is either full of water still, or needs to go through an extra "rinse and spin" cycle to drain the...
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely, if the issue returns then it is time for a new pump. Hope this helps... Please post back for any further assistance.
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
Manf# MAV5000AWW My toploading washing machine goes through all cycles but the last spin cycle the clothes are still soaked and i have to sring the excess water out by hand
If the machine is not pumping out completely, it could mean a blocked drain hose or a faulty/blocked pump. This would explain wet clothes However if the mache is not actually spinning it will leave the clothes wet,as well. Check and ascertain which function is not working.........Nomess
Apr 17, 2010 | Washing Machines
The door won't open after a cycle...and all the clothes are soaking wet..even after 2 spin cycles it still has a lot of (soapy) water at the bottom..Help!!
the most common problem is a blocked or restricted drain pump.You can use a wet/dry Shop vac and attach it to the end of the drain hose to remove all the water.
Once the water is removed then your door should unlck and you can remove all the clothes.
after that you need to look at your drain pump remove the hoses be sure to check the hose that comes down from the bottom of the tub to the drain pump and look for any obstruction also check your drain pump inside there could be something stuck in it.
Feb 24, 2010 | Washing Machines
Clothes as still wet when it is finish after washing is done
Hello Sassylips,
Clothes will always be wet after a wash but if you are saying that they are soaking wet rather than just damp from a frontloadre like yours then you may have an obstruction in the pump system.. That could be anything from a screen preceding the pump, some obstruction in the pump itself, a pinched or clogged drain line exitting the washer or restrictive flow in your home drain system. A simple check that can be done would be to take the drain line out of the house drain and put it in a barrel. Watch the flow of water when the washer cycles thru a standard wash and see if it appears to be a reasonable level. A trickle would indicate one of the problems I mentioned previously. Have you ever cleaned the drain screen? Those are a few potential issues that could cause your clothes to remain wetter than they should be after a wash cycle. Also, you might try washing a few articles of clothing and then check to see if they are as wet as larger loads when the cycle is complete... Hope these ideas help you identify the cause and are able to resolve your problem...
Nov 29, 2009 | Frigidaire ATF6000ES Front Load Washer
My machine will wash and rince but shuts off when
That may be dirt at the filter of the pump. check the drain hose aswell for any thing blocking the drain system. remove the hose before the drain pump.
Aug 06, 2009 | Frigidaire Affinity ATF6000F Front Load...
Washer does not complete its cycle on any wash cycle. Error Code F 02 shows up before rinse and spin is complete. Clothes are soaking wet. What is the problem?
check the drain hose for any blockages or kinks and check to make sure water passes through it freely. it may be that it's just not emtying quick enough and therefore clothes remain wet. in a worse case scenario the pump itself could be faulty :(
Oct 27, 2008 | Whirlpool Washing Machines
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
Kenmore 4292x Front Load Washer Logo
66 people viewed this question
Sal De
 Brian Main
Brian Main
