Question about Beko 24 in. D3421F Free-standing Dishwasher
Beko D3421FS free-standing dishwasher
Sometimes it washes normally but increasingly more frequently the time clock races through the programmes (I've tried all of them) in about 5 minutes and at best my dishes get a cold rinse.   Is it the programmer at fault or a sensor or something else please?
  • Bekoturk Nov 08, 2008
    Thanks, I thought most probably it would be the programmer. The costs of replacement compared with scrapping and buying a new appliance would be worthwhile if I could be more sure that would fix the problem otherwise I have visions of 'throwing good money after bad'. Is there any other expert who has experience of this problem or have I simply not given enough information for a definitive reply?
  • Beko Master
  • 19,396 Answers
If the cycler goes to slow or get stuck, then tere may be more than one reason.
If instead, like in your case, the cycler goes to fast, then is undoubtfully a faulty cycler.
If you enter the exact model number on this website you can find the replacement part.
Posted on Nov 08, 2008
  • 83 Answers
Try following link check your dishwasher
h**p://home.howstuffworks.com/how-to-repair-a-dishwasher.htm
    Sergeant:
    Novelist:
  • 196 Answers
As per my knowledge your machine needs servicing and readjusting in it.just off the machine remove all the stuff from the machine that you have put in it for cleaning.just make it totally empty and clean it manually.then adjust the temprature properly as you start it again.and then check.if the problem further exists .you need a technician at your place to locate the fauly exactly by checking it through meter.
Posted on Nov 07, 2008
    Scholar:
  • 155 Answers
Most probably the programmer is having some problem.
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
We are a retirement association who can't use our dishwasher as there is no instruction book HELP please
I have done a long search and the manuals I can locate for Beko diswashers are here:
http://www.retrevo.com/samples/Beko-manuals.html
and here:
http://www.beko.co.uk/Manuals.aspx
Use this link and then go to the right side search panel and search for full sized dishwashers. (9 models)
I reommend you use this link below and ask if they can provide you with a manual.
Beko Customer Support
http://www.beko.co.uk/Contactus.aspx
I did not find the D3421FS as an exact match.
images?q=tbn:and9gcroxhdxl1uym3gjptjmamvwbrjwfucsrt88rvwupqjtgazmzmnx1mt9kg
Thanks for choosing FixYa,
Kelly
Mar 25, 2011 | Dishwashers
The washing machine belt keeps coming off any ideas why, should it have any stoppers or something to keep it from sliding off thanx . beko wma1512s
Belt would have become expanded after use. Try adjusting the motor base by moving in the direction it tensions the belt. Or replace with the identical belt No. Clean belt resting area free from any old belt rubber deposits /markings.
Apr 16, 2010 | Beko 24 in. D3731F Free-standing...
My beko eco care d3421fw dishwasher won't fil with
i have beko glacier fridge freezer.the freezer section works as normal but the fridge section only works sometimes.the pump only starts after you hear a click sound from the back of the fridge.is there a starter component that activates the pump.
May 22, 2009 | Beko 24 in. D3421F Free-standing...
Beko washing machine fills with water when not in use!!
hi there.....you got a faulty water inlet valve on the machine ..change this and all will be fine again...
regards Sir Galahad
Dec 05, 2008 | Beko 24 in. D3421F Free-standing...
How do i re-set my dishwasher
If by reset you mean cancel the programme, then you need to press and hold the start/pause button for about 10 seconds until the drain pump starts to run.
This will continue for about 2 minutes.When it stops, turn off the appliance. When you turn on again all should be well
Nov 30, 2008 | Beko 24 in. D3421F Free-standing...
hi there.......this problem could be caused by a failed heater element ...if the element is not heating the machine will just wash wash etc...the front panel will have to be removed to check the heater element....if the element is ok...check the heater NTC ( little white plug in the heater element)...if all ok here....then you have a main PCB board failure....
it may be more economic to have beko send an engineer to you...
regards Sir Galahad
Nov 03, 2008 | Beko 24 in. D3421F Free-standing...
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Diswasher will not fill clock stays at 130 an
This is either a fill fault or a heater fault, for fill fault check side fill chamber is not blocked with fat, for heater check heater, if heater does not activate then the fault is on the PCB programmer, this model often suffers from faulty soldered connections on the pcd, remoce and inspect if required resolder joint. Regards Advisor
Aug 19, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Beko 24 in. D3421F Free-standing Dishwasher Logo
78 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
