Question about GE 29460GE2 Corded Phone
Static in the GE 29460 GE-2
1. Problem for this phone has been narrowed down to the receiver. There is much static when using the receiver vs none when using the speaker. There is no static in other phones in the house. Tried a new cord in the receiver, but static still remains.
2. Phone works just fine with NO batteries at all. What's the purpose of the batteries?
Thanks for your help.
I have the same problem with my GE 29460 GE-2 phone. I took apart the handset and the source of the humming and static is a bad (cheap) microphone. I have swapped in a spare handset from another phone which works for the time being... it doesn't fit the phone cradle very well. When I find a junked phone (any wired phone would probably work) with a good microphone I may try soldering in the mike into the old handset... its only a 2 wire solder job. I'm PO'd at GE for making junk so I don't want to buy the parts for this, if I could find them.
Posted on Jan 08, 2009
How do I get the sim card out of my I phone 5?
Turn the phone COMPLETELY OFF.
- Put on your anti-static wrist band.
Remove the protective case ...
if you have one on your phone.
On the right side of your phone...
observe a narrow 5/8 inch slot with a small hole in it...
Using the appropriate release pin... (or small paper lip)
gently push into the hole and this will release your
SIM CARD...
Keep in mind THE tiniest STATIC spark can
(you might not even feel) utterly destroy the
most ROBUST of semi-conductors...
EVEN those big UGLY diodes in your cars alternator...
so always wear ESD (electro static discharge)
protection when handling any semi-conductors
YOU CARE ABOUT.
See below
Nov 17, 2016 | Cell Phones
Sharp Aquos LC-52D92U static on display
if your seeing static on a digital tv , your problem is "Not" in the tv its in the signal source (cable box, sat scram,Etc)
digital tvs cant produce "static" displays because they don't receive wide spectrum signals like analog TV's did (carol-ann knows this!) there "filters" are very narrow and specific , this is also why there range is dramatically smaller than analog tvs
also everyone by now knows that tv stations can no longer transmit in analog format (in Usa), G4 cell phones got there band space
Jun 29, 2015 | Sharp Televison & Video
Norstar line static
Most likley not a phone issue since you say its a line.
Call your carrier (i.e Bell, AT&T ect) whom supplies your phone lines to fix it.
Jul 23, 2012 | NorStar M7324 Telephone
Denon avr-3200
Check a few things first to narrow this down a bit. Disable the surround processing. If this clears up that channel, then the problem is in the processing area. If the static remains, vary the volume. Does the static change volume too? If so, then the problem is in the beginning stages of the pre-amp section and is likely a transistor or two breaking down. The parts for this would be in the $5 range. This would probably be considered a "major' repair becaue of the time required to hunt down the defective part.
Dan
Mar 28, 2010 | Denon AVR-3200 Receiver
My receiver is making a static through my speakers even when the volume is turned all the way down
Check the electric outlet to make sure the polarity isn't reversed, which can cause static. Also, check the outlets in the room to make sure they are all grounded which can also produce static. Also, certain cell phones operating a different frequencies can produce a static.
Feb 25, 2010 | Denon DRA-275R
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
Heavy Static on phones. Can't hear caller. No caller ID
Room monitoring mode is basically a type of Intercom.
Press the *TONE/exit button on the handset to exit room monitor mode.
I will provide you with link to the user manual of the phone. Have a check at it. Might be useful.
http://www.home-electronics.net/ge/pc/IB/28112EE1_IB.pdf
May 30, 2009 | GE 28112 Trio Cordless Phone
Only get static when trying to receive transmission
Turn the squelch knob eathier up or down to eliminate the static.
Oct 14, 2008 | Audiovox FR2302 2-Way Radio
GE Spacemake XL1400 Display
This may seem strange but my microwave ended up doing the same thing..the solution courtesy of another website pointed toward RF interference from that faulty magnetron ge is famous for...what cure it was piece of the static paper used to protect computer parts..check it out by opening the side panel and leaning it away from the magnetron.mind started up immediately no problem ..got a piect of the static paper,fashioned it to fit...and problem solved
Oct 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE 29460GE2 Corded Phone Logo
269 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
