Question about Oreck XL Ultra Bagged Upright Vacuum
Wiring schematic oreck xl2600hh
Had to replace main housing at motor and i did'nt mark wiring connections on motor.if you can send a schematic or tell me where i can get one. thanks for your help. alan.
I have a Oreck XL and the propeller that is in the housing will become hard for the moter to turn. I have took it apart and do not see a problem, but when I reinstall the parts it will run for about 15 sec. and the moter will stop turning. When the propeller housing is off the motor turns ok and doesn't stop. Do I need a new propeller/housing?
Posted on Nov 13, 2009
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Xl2600hhvacuum won't stand alone anymore, what is broken, is it a spring or some kind of catch missing
The detent that is mounted to the inside of the base cover is not working either because the screw holding has broken off or it is worn out. You could also have a worn out fan housing since that is what the detent catches to make it stand up. If the screw is broken off the only way to repair it is to replace the housing. Hope this helps.
Jul 15, 2013 | Oreck XL2600HH Upright Vacuum Cleaner...
On/off switch for Oreck XL2600HH
Would have to assume by now you figured this out. However, need to open up the handle. It is a clamshell arrangement. Remove switch from handle, pull one wire at a time from the switch. The electrical connectors are a push-on type. Replace each one, one at a time, to the new switch, and then re-insert switch into handle. Close up the clamshell, tightening all of the screws, but do not strip the plastic housing.
Jun 19, 2009 | Oreck XL2600 Vacuum
Hi, I appreciate your wiring diagram for the Oreck XL motor --but it is too small to read. Could you send me a readable copy. Thanks very much for your help! Nels Klyver
Print out the diagram u have, then scan it and blow it up to a larger size (all scanner allow u to enlarge the image), this is what I do with hard to read electrical diagrams.
Apr 28, 2009 | Vacuums
Model Oreck 2600HH- need schematic
white to motor terminal,black to other motor terminal,green is always ground to housing there is a small terminal tucked away its s small spot for the lights
Feb 01, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Clear oreck schematic
Here is Oreck's motor wiring diagram, if it isn't big enough to make out, give me your email addy and I will send it to you.
Oct 01, 2008 | Oreck XL21 Bagged Upright Vacuum
Wiring Schematices
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Mar 31, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Rplacement part
http://www.oreck.com/customer-service/owners-guides.cfm#
Her is the oreck manuals web page.
They can also tell you where to get parts.
Feb 20, 2008 | Oreck XLS700A Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
688 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
