Question about Emerson EWD7004 DVD Player
Panel front the front panel buttons have never worked since first purchased. all functions work perfectly but only by using the remote. the second unit purchased front panel buttons worked fine is there some sort of lock etc????
    Sergeant:
  • 337 Answers
The first unit might have a broken or crack front panel,is possible since it was purchased new,it will be a good idea to remove the top cover and try to see if something is broken in the front,you can also remove the front and have a better look.Let Us know how it goes,make sure the unit is not plug in if you try it.
Posted on Oct 14, 2006
  • Omar Urrutia
    Omar Urrutia Oct 14, 2006
    Your rating resonse is important to the person helping you.
SOURCE:
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Tv has worked for ever with the remote now remote has failed and the on off swutch doesnt work to turn it on and off How can I program another remote if I can turn it on?
First, check to make sure the front keyboard is not locked out. Press and hold the menu key for 10 seconds then release. If it was locked out, then front panel buttons should work. If no change, you likely have a problem with one of the ten contact switches on that panel. Remove the front speaker grill by pulling it off, then trace the wires from the front control panel (you may need to remove the cover off the front of TV). Unplug the wires to the front panel and try by Remote control. If the remote works, you can purchase ten tact switches and install or just leave the wires unplugged and use it like that.
Bill W
integrityhomeworx.com
Mar 13, 2011 | Mitsubishi WS-65411 65" Rear Projection...
We have a Samsung Digital Home Theater System HT-DM150. After some guests were fiddling with the remote, we find that we cannot eject a DVD that was inserted. The DVD plays OK, but when we try to eject,...
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jul 05, 2009 | Samsung Audio Players & Recorders
Display reads OPEN LOCK when I try to open dvd tray.
Jun 26, 2009 | Samsung HT-DS610 System
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
Jun 27, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Child lock?
To turn on the dealer lock function: Turn the DVD player on. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds. Note: When the dealer lock function is active, DEALER LOCK ON or DEALER LOCK OFF scrolls on the FLT display. this is from samsung's site
Jun 07, 2007 | Samsung HTDM150 System
Remote Won't Work! Problem with TV remote receptor?
Try unplugging the set for 12 to 24 hours. if that does not work, theres a problem in the remote sensor circuit or the microprocessor circuit. its going to need a pro to fix it as it meeds trouble shooting.
Sep 05, 2006 | Toshiba 32AF41 32" TV
Emerson EWD7004 DVD Player Logo
46 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
