Question about Kenmore 92022 / 92024 / 92025 / 92029 Electric Kitchen Range
Kenmore electric range won't work
I had the power to a house turned off for a week and now the range does not work after turning the power back on. Its a smooth top 790.92889302. The display works and one burner sort of works but not enough to boil a pot of water. The oven doesn't work either.
  • MACKAMBOLEE4 Nov 29, 2008
    the only thing that's not working on my kenmore is the eletric oven.can someone help me?mackambolee44@aol.com
Well I got it to work. All I did was unplug it and then plug it back in. Apparently it wasn't getting current from both of the 120v legs, just one of them. Re-plugging it made contact with both legs.
Posted on Nov 10, 2008
Kenmore oven/range doesn't work after turning power to my house off and back on.
a oven range is 240 volts , and will be a 40 or 50 amp double breaker make sure both breakers reset ,or you wont be getting but a120 volts to the range , not enough power .it looks like a single breaker but it is a double...
Jul 29, 2012 | Kenmore Kitchen Ranges
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Got F40 error code self-cleaning my 790.9642 Kenmore range
try this, after several calls I finally found out what the code meant. code meant. Power supply issues, not necessarily with your power supply but with the appliance2_bing.gif itself. Of course they want to send a technician for $65.00, which may be worth the headache. All someone told me was to turn off the power braker for 2 hours and try again. Yeah right, after 2 hours of heating your house and paying the electric bill, but when breaker is off there will not be any electric used. code f40,
Apr 18, 2010 | Kenmore Kitchen Ranges
The power went out in the house. When the power came back on the oven would not work. The pre-heat red light keeps blinking
turn the oven off and disconnect the power to it for 10 minutes, then re connect it and try it again, see if it resets the system controls, if not the power surge that sometimes occurs when power returns has damaged your range, most utility companies will pay to have this type of electrical appliance fixed due to there power surge, contact them for a claim form in the event the oven doesn't start working after the power is reconnected.
Oct 23, 2009 | Kenmore 94022 / 94024 / 94029 Electric...
Broiler Stuck On - Want to Disconnect
Yes, you can remove the broiler element. Usually they are just plug in after you unseat them If there are wire leads, you must follow them back and remove them from their terminal. If you follow the lead back to the terminal, you may just remove them with a pair of pliers and pull the burner out.
Apr 25, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
No heat Maytag smoothtop range MERH752BAB
It would have to be under warranty if this happened after only 1 week. I would contact the manufacturer.
Sep 08, 2007 | Kitchen Ranges
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kenmore 92022 / 92024 / 92025 / 92029 Electric Kitchen Range Logo
326 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
