Question about Hotpoint RGB745 Gas Kitchen Range
New igniter, still won't work
That was the oven. Now the broiler has gone out too. Connected somehow maybe?
I'm mechanical, shoot me the scoop how to test. Thanks!
clarkjohnsen@gmail.com
  • clarkjohnsen Nov 06, 2008
    "Ignitor should begin to glow."
    "Should"... that word again. Indeed it should, and if it did I'd be cookin'! (Or, roastin'.)
    As stated, it's a new ignitor that tests good. Therefore I guess I'm looking for why there's no voltage. The lights do go on, so it's plugged in.
    Look forward to another round with you, thanks.
    cj
  • clarkjohnsen Dec 11, 2008
    Problem persists, but I had to flee the jurisdiction for a few weeks. ;-)
    I posted this as the RGB745. The bake & broil ignitors are different, but that's not the problem. Neither one of them now works, and I have TWO new bake ignitors that test fine on a meter but neither one works. Obviously something else is wrong and so I'm still looking for a circuit diagram, preferably with hints for fixing.
    So I remain in the state of HELP!
    clark
  • 1,543 Answers
Turn on oven. Ignitor should begin to glow. (if no glow after 30 seconds or so, check to make sure you have 120 volts to ignitor) Observe amperage draw using a clamp on amp meter. When amperage reaches 3.2 to 3.6 (for square syle ignitors) the oven safety valve should open, releasing gas and lighting the burner when the gas hits the red hot ignitor. For broiler, just substitute the word broiler for oven. Old ignitors get " weak " and may not draw enough amperage to allow safety valve to open. Also, voltage will affect the amperage draw, as lower voltage = lower amp draw.
Posted on Nov 06, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 14, 2008
    Have not heard back from you. Have you solved your problem? Don't know if you posted under your exact model number (many posters don't) but most self clean gas ranges use the same part number for the broil and bake ignitor. If your broiler works, you could try switching the ignitors and see if that fixes the oven. If it does, you'll obviously have to get a new ignitor for the broiler now or that won't work, nor will the self clean.
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
My top broiler won't turn on. Everything else works fine. I have exchanged the top broiler element with the bottom. So I know it isn't the element.
Could be wiring. Did it work before? Maybe, never connected? Could be demand of two oven's and or broilers at the same time exceeded the wire and circuit breaker capacity when installed and therefore were never connected.
Otherwise thermostat. Probably need appliance Tec or Electrician.
Mar 04, 2015 | GE JTP27 Electric Double Oven
I have a maytag model # mgr5775qdw and the oven will not ignite. I know it is not the gas line as the burners all light, and the broiler lights as well. It is only the oven that does not heat. . .what...
This could be two possible problems. The igniter maybe bad, but doubt it. The igniter works both the oven and broiler, I believe on this model. The first thing I suspect is the switch in your wiring harness. The harness has a switch attached to it for each manifold. The switch for your oven maybe out.
Go to this site for diagram of parts: https://www.maytag.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10282172.pdf
Jun 18, 2011 | Maytag Ovens
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Broiler works oven doesn't heat
Based on your description, the igniter is dead.
The broiler and the oven heat each have their own igniter. Look for the characteristic glow when the oven is turned on. If it is not visible, then you will need to replace the "OVEN" igniter...
Google the stove model for repair parts and locate the igniter. Not too hard to replace... directions are packed with the new igniter...
Jan 08, 2010 | Maytag MGR5750 Gas Kitchen Range
I have a Whirlpool Gold oven model GW395LEGB5 that won't heat. The broiler works fine. Sometimes, after the broiler is lit, the oven will heat up. But no more. Just the broiler works. Is this...
If the broiler works fine, but the oven does not, more than likely this is caused by an igniter that has gone bad. The intermittent symptoms you were experiencing is a sign that the ingiter probably became weak due to age and finally failed. The following link explains how these igniters work and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Since both oven manifolds are fed from the same gas source, this can be narrowed down to an igniter problem. Your oven should have the Norton type igniter. The part number for a replacement is 9782065 and can be found at appliancepartspros.com for about $71, You can search around if you like, but this was the cheapest I could find it.
Your oven has interchangeable igniters. Meaning the broil manifold and bake manifold use the same type of igniter. You can swap igniters while awaiting parts, if you wish to use the oven to bake.
NOTE: If the connector plug on the ingiter you receive does not match the receptacle in your stove, you will instructed to cut the leads and connect them together using ceramic wire lugs (included in the kit you receive). Do not attempt to use standard wire lugs as they will melt. The wires and ceramic lugs are heat resistant.
If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Sep 07, 2009 | Kitchen Ranges
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
No spark to top burners, oven & broil will not light
it sound's like the spark module you might be going in too deep
Nov 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
Hotpoint RGB745 Gas Kitchen Range Logo
302 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
