Question about Canon PIXMA iP4300 InkJet Photo Printer
Cannot delete print job
I saw a similar issue posted under a generic print issue, but the solution was only provided for a PC. I have a Canon Pixma iP4300 on a Mac and have not been able to delete a item from the print queue. It currently reads "on hold" and that it was "completed" but I can't "resume" or "delete" it. Thanks
  • debdlee Nov 06, 2008
    Thanks, although it didn't solve the issue. I followed steps 1-3, disconnecting and reconnecting the USB cable from the printer and computer. It didn't start printing the job and the job remains on hold in the queue. What is the next step? thank you
  • debdlee Nov 07, 2008
    I went through all of the steps on hp and the last one with deleting and adding the printer finally worked. Thanks!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
Follow these steps in the order presented to resolve the issue. After you have resolved the issue, you do not need to complete any remaining steps. Step one: Check the USB cable
  1. Disconnect the USB cable from the product, and then disconnect it from the computer.
  2. Wait 10 seconds.
  3. Reconnect the USB cable to the product, and then reconnect it to the computer.
After you connect the product directly to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step. /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Posted on Nov 06, 2008
My printer wont print
1. check if the printer is connected to the PC.
2. see if the status on the print manager of the printer is not set to "offline" --- just do a right click on the printer icon under printers.
3. see if you have the updated print drivers from the canon website or windows update.
4. check if there are any print jobs spooling that are on error mode. either clear them up (delete) or try restarting them.
5. reboot your PC and try again. :)
Nov 07, 2013 | Canon PIXMA MX892 multifunction printer
Canon pixma mp610 cant delete the printing queue or print
This is not the fault of the printer but windows. Open the Control Panel, select Devices & Printers, find your printer, click on it, select Delete Print Queue. Problem is fixed.
Jan 07, 2013 | Canon PIXMA MP610 InkJet Printer
Canon pixma ip 3000 will not exit the error mode. every time i try to rest it it retunrs, any ideas?
Try turning it off at the mains, it should re set the printer.
Also you can if you have any print jobs in the printer que delete them, you can find that by going to your system tray, normaly if there are items waiting to be printed your printer should be residing there, right click it & choose your printer, from within the screens that are open you should see print jobs in que, select them & delete them
Nov 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
How to delete past jobs?
This is the method to delete print jobs in the Queue by Microsoft.
If this is not working, then try this method.
Press Winkey+r
In the run dialog write msconfig
An other dialog-box will appear, there you will see many tabs (Click Services)
In the list find "Print Spooler" (UNCHECK it)
Click Apply,
Restart Your PC, and turn on the service again by Checking it (It may Start Automatically)
Another Method:
Open your C:\ Driver
Goto Windows folder
Then System32 folder
Goto spool folder
In the spool folder there will be a folder named PRINTERS
Delete all the files in that Folder.
You are done.
Hopefully, one of them will work, Best of Luck.
Regards,
Waqar.
Aug 20, 2009 | Canon PIXMA iP90 Mobile Printer
Erase queue
Stop and restart the print spool service through the services console.
Start > Run > Type services.msc
Press ENTER or click OK/RUN
Locate the Print Spooler service.
Stop the service.
Restart the service.
Now troubleshoot your printer issue.
"Superhiway"
Jul 12, 2009 | Canon PIXMA MP800 All-In-One InkJet...
Showing printer error 6A00
I just copy this solution for you to this link:
the solution is posted by BAB..
they have the same problem as you ..then this solution solve it..^^
http://www.fixyourownprinter.com/forums/inkjet/39177
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
May 19, 2009 | Canon PIXMA MP610 InkJet Printer
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
PRINTER CANON PIXMA IP1500
your printer maybe long period of time does not use , the head already dry , replace w/ " original canon ink" not a generic.
Dec 28, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
167 people viewed this question
old marine
old marine
