Question about Samsung SR4000 35mm SLR Camera
On the little screen it keeps saying error 04.
I dont know maybe its something simple that i can fix but i really dont know. i have no clue.
0 characters
1 Points
The mini DV tape deck of my Sony camcorder will not eject the cassette. How do I fix this?!?
I dont realy have much clue but have you tried switching it off for some minutes and then put it on and try ejecting again? If you havent, try it and see if it helps
Mar 28, 2013 | 35mm SLR Cameras
My Nikon F80 won't load y film automatically, it has a FEE error on the screen but i don't know what that is??
The lens you are using has the aperture ring set to something the camera cannot use. Simply turn the aperture ring to the largest number, usually a 22 or 32. Lock that ring if there is a lock and the fee should be gone.
Aug 31, 2012 | Nikon F80 35mm Film Camera
Hi, I recetly purchased an X-700. Every thing seems OK except that the shutter speed control knob seems loose. I mean it works allright but can move up and down, can tilt .... I dont know if how to...
There's a little silver ring on the inside with two little notches in it. try putting a toothpick or something small in one of these notches and turning it to the right to tighten it.
Jan 02, 2011 | Minolta X-700 35mm SLR Camera
I tried to put my pictures onto my computer last night but the computer froze so I gave up but I took pictures this morning, and it was fine. Then the next picture I went to take nothing showed up on the...
Your coin battery that powers the memory system of your camera may be failing. This battery keeps your settings and powers your on board computer. Do not confuse this with your picture battery, as that only powers the lens and picture taking ability. The coin battery holds the program. See page 38 of your manual "Replacing the Date/Time battery."
Dec 20, 2010 | Canon EOS Rebel XS 35mm SLR Camera
I recently bought a reconditioned FA from a reputable dealer, but on running my first film through it over Christmas, wasted 6 frames when the wind on lever failed to reset the shutter. Unsure what to do,...
Dave, do you realise just how incredibly mechanically complex your camera is?.
The shutter has not reset, all that's happened is that your sticking shutter has now progressed to a partially seized shutter release. The dark grey viewfinder indicates that the mirror inside the lens throat has stuck in the partially up (or partially down) position. This might just be something really simple like dirty shutter magnets, but if the camera was serviced before sale then that should have been spotted and corrected. Sadly, many dealers just give the camera a wipe over with a cloth, maybe a little bit of fresh paint on worn corners and a set of fresh batteries and claim that the camera has had a full service before sale.
Buying from a reputable dealer always attracts a price premium as such dealers are supposed to give full after-sales care. Just take it back for a refund or repair. Given that there are thousands of good FA's around (my last two were free on FreeCycle/Freegle), and that the dealer should have ensured that yours was in perfect condition before selling it, I'd personally demand a refund especially if you're in the UK (likely from your spelling of "grey") with the protection given by the Sale of Goods Act. Allowing the dealer to try and repair the fault will weaken your right to a refund under the Act, and any attempt to repair the fault yourself will completely void your consumer protection.
One other point to consider is that, worldwide, there are far fewer camera repair outlets than there used to be, and so you can usually expect to wait around six weeks for a repair unless paying far more for an express repair. This may be different if your dealer is one which has it's own qualified camera repair technician and is worth asking about if you consider letting them repair your camera.
I hope that my posting has clarified matters for you and will help you to make the correct decision. Good luck with a speedy resolution. Please return the favour by taking a moment to rate my answer.
Jan 11, 2010 | Nikon FA 35mm SLR Camera
Error 99
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable. Alternately, it can also be a card error or camera error.
First remove the lens, battery and card and leave the camera like that for about 30 min. After that, insert a fully charged battery and switch on the camera. If the error still shows up, it is a fault with the camera and has to be serviced.
If not, turn the camera off and insert the card. Format the card in the camera and depress the shutter button. If it shows an error, the card is faulty.
If not,
try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting.
If the error still shows up, you need to take the lens to an authorized service center.
Dec 07, 2009 | Canon EOS Rebel G 35mm SLR Camera
Film loading problem Minolta Maxxum 430SI RZ
not solution, but a suggestion, something to look for/try.
i think it is trying to tighten it and take up the slack in the spool. there might be little red dots or something like that on the inside when you open it up. you are supposed to have the film go to a certain spot before you close it. normally, the film is sticking out the right length, but you might have to pull it out extra first. you might also have to tuck the end of the film behind a roller or in front of a roller before you close it. look for really tiny diagrams inside the camera, or maybe just tiny arrows indicating which way the film is supposed to wind. good luck with your class!
Jan 20, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Rectangle piece keeps falling out when I take lens off.
That's the Acute Matte Focusing Screen. They are made to be swappable and easily installed. While I don't know the specifics of your camera (I own a Maxxum 7000), I can assure you it's probably easily fixed, and probably not actually broken. Most likely, it's retainer just let go.
Jan 09, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Aoutofocus stopped working
Start off with the simple things, does it work with another lens, is the AF/M switch in the correct postion for autofocus (AF), are the batteries good.
If all of the above are in order it maybe either the DC/DC converter on the bottom of the camera, this supplies power to various parts of the circuit. or it could be the motor drive transistors, these are located under the front cover and are located where you finger tips rest on the right hand side as you hold the camera.
Both these items are not really user changeable and I know the DC/DC units have not been available new for many years now.
I suggest you have a look for a friendly camera repair shop to pin point the exact cause.
You will have to keep in mind the age of the camera 23 years old parts are a big issue
Sep 06, 2008 | Minolta Maxxum 7000 35mm SLR Camera
T70 LCD display
I also have t-70 that I bought when they were released and I worry about the same thing. Everything that I have been able to find on the internet is that Canon no longer makes replacements and no third party has come forward with one. I went on Ebay and found another t-70 that is in excellent condition for $50.00 to use as a parts donor in case something happens to my original. The only bad thing is that I have been using that one also, I keep that one loaded with B+W and the original loaded with color.
Jul 16, 2008 | Canon T70 35mm SLR Camera
Samsung SR4000 35mm SLR Camera Logo
23 people viewed this question
Top Samsung 35mm SLR Cameras Experts
old marine
old marine
Ric Donato
Are you a Samsung 35mm SLR Camera Expert? Answer questions, earn points and help others
