Question about Kenmore 20172 Top Load Washer
Kenmore elite stops filling with water
The washer will fill for a few seconds, stops filling and just hums
  • 1 more comment
  • redhawk350 Nov 08, 2008
    I'm not sure, the timer display just shows the time remaining for the cycle.
    Thank you I will check that.
  • jason May 11, 2010
    whats the fault code?
  • 905 Answers
Then you will need to shut off the water and disconnect the water inlet line and check the filter screen for the water in , if that has rust deposit build up then this will cause problems like that , but if this doesn't seem to help then there is most likely something wrong with the way the water is let in , and it will need to be looked at to find out what is not working correctly or what is stopping the water from comming in
please give a fixya rating as everthing but a fixya will just hurt our rating which then makes us just not to want to help anymore, sorry but that is fixya doing this scoring ,but i will be happy to assist you if you further need it , thanks
electech
Posted on Nov 08, 2008
  • jason Nov 09, 2008
    ok , thank you! ,and if that don't do it then the solenoid that holds the water valve open durring the fill cycle is probably failing and will need to be replaced, so further damage is not caused by the strain of the circuit
    if you still need help , i'll be back and answer any other question that you might have
    again thanks!
    electech
Washer stop before completely filled with water.
beko washing machine when turn it on it trips
Dec 12, 2009 | Kenmore Washing Machines
My washer continually fills with water
your fill valve is stuck open replace fill valve
Sep 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore ht4 front load washer
this seems to be a control panel issue. if water valve switches, try hot /cold water combos to see if it will start filling
Aug 31, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Full of water wont drain
had trouble with some washers not dumping water found penny screws and other small material in the pump removed and worked o k .this might help.hum might be from restriction in pump.
May 21, 2009 | Kenmore Washing Machines
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 20172 Top Load Washer Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
