Hyundai ImageQuest ImageQuest V995  19" CRT Monitor
Problem for Hyundai ImageQuest ImageQuest V995 (White) 19" CRT Monitor
Switching to "off mode"
By mrfish on Oct 14, 2006
whenever i turn on my computer which i had recently updated, the monitor does not turn on it remains on standby and when i press any of the buttons on the monitor is says that it is in off mode. the monitor refuses to turn on no matter what i do to it. please help
Same Problem
Jul 18, 2008
-   i have a Hp mx70 desktop moniter and i just installed windows xp but right before the computer loads to user log screen it shuts off and when i try to turn it back on it imedietly shuts off again-   kayboe90
Solution #1
posted on Oct 16, 2006
Somewhat Helpful)
dugiehowsa
Rank: Wiz
Rating: 77%, 871 votes
Sounds like your video adapter settings have been wedged. If you are running Windows XP Service Pack 2, you can use the following steps.
1) Boot the laptop into safe mode. Boot into safe mode with networking support if possible. This can be done by tapping the F8 key as the computer first turns on.
2) Once you are at the Desktop, right click on My Computer and select Manage.
3) In the window that appears, select Device Manager from the menu on the left.
4) Find Display Adapters on the right and click the plus sign. This will list the video adapter that you have.
NOTE: WRITE this down EXACTLY. You may need to go and get drivers for this. Seeing this is an older model, I doubt you'll need it, but better to be safe then sorry.
5) Go to your manufacturers support web site and download these drivers. You may not need them, but better to be safe then sorry.
NOTE: Skip step 5 if you did not boot with network support or cannot get to the Internet. This can be done from normal mode.
6) Right click on the display adpater and choose un-install. Hit OK on the window that appears and reboot the machine when the process is done.
7) The machine will take longer than usual to boot, as Windows XP is re-discovering the video adapter and resetting everything to the defaults. When it is done booting, the screen may look weird since the settings are now the defaults. You can the set them to what you want by right clicking on the desktop and selecting properties. Then go to the settings tab.
8) IF it did not re-discover the video adapter (this can be confirmed through the device manager), then go ahead and install the drivers. Windows Update will most likely also have the drivers.
Was this helpful?
Yes
No
Solution #2
posted on Jul 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You are making the assumption that I have two monitors! If I had two monitors, I would be looking for a fix, I'd burn the other one.
Popular Solutions for Hyundai ImageQuest ImageQuest
Questions and Unsolved Problems for Hyundai ImageQuest ImageQuest
Do you recommend Hyundai ImageQuest ImageQuest V995 (White) 19" CRT Monitor?
Answer
Answer
I have a balance digital technology monitor model # Cm2017 and i need a power cord for it and do not... (More)
Answer
Hi,HYUNDAI N91SNo sound, What do I doHugh C
Answer
I was trying to adjust the brightness of the moniter display for an e-card, and now I can't see the... (More)
Answer
Hello, I have an Imagequest V995 monitor from a friend. Unfortunately the VGA connector was damaged... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hyundai ImageQuest ImageQuest...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
