Question about Dometic Rooftop RV Air Conditioner
DUO DERM ROOF TOP AIR
WARM AIR NOT COLD, A MOBILE HOME GUY SAYS IF YOU LET THE AIR CONDITIONER SET FOR A FEW YEARS THE COMPRESSOR FREEZES UP, IS THAT TRUE?
  • 899 Answers
Yes , this can happen if it sets to long , thats why even cars pumps are engaged when even the heat is turned on , to keep the compressor from siezing up
Posted on Nov 06, 2008
Hi, i just bought a second hand amcor air conditioner but it dosent send hot air, what can be the problem?
Air conditioners normally blow cold air, unless it has a built in heat pump. You should post the model with your questions.
Jan 08, 2017 | Amcor Heating & Cooling
What does Ft mean on a TCL portable air conditioner
FI - Failure1
This message could appear if the water filter is particularly clogged. See section: "Re-placing the limescale filter".
If the filter has been replaced recently, contact your local authorised service centre.
http://airmaster.net/delonghi-portable-air-conditioner-troubleshooting/
http://acerrorcode.com/tcl-air-conditioner-error-codes.html
Jan 06, 2017 | Heating & Cooling
I have a older Carrier heat pump, model 38YKC060. Does anyone know how cold it will continue to work at?
Heat pumps are of little or no value at temps around 40 degrees or below. And if you use the strips it will cost a small fortune if you have relatively high electric rates as most folks do.
Jan 04, 2017 | Heating & Cooling
We have royal red furnace to heat our home.The fan dose not stop.
Details.......does the furnace function normally otherwise? Might just be a stuck fan switch. Make sure the thermostat hasn't been set on Fan ON setting or summer air circ. on older furnaces.
Find the fan switch and tap it and see if fan quits. If it does,fan switch is bad.probably. Always make sure your air circ. filter(return air to furnace) is replaced every 3 mo. or so,too. don-ohio (:^)
Jan 03, 2017 | Royal Heating & Cooling
It is 9 degrees outside and my duo therm furnace is blowing cold air
I hope you have fixed it by now. Probably was the limit switch? don-ohio
Dec 18, 2016 | Heating & Cooling
Why does my home A/C unit result in a constant stream of water coming out of the overflow drain? I've had the same unit for 5 years, and it seems that it drains water in ever-increasing amounts. Als
Sounds like it is freezing up. Kind of hard to say since you did not say whether it is a central heat and air system. My overflow was constantly draining onto my patio from overflow. I crawled up in the attic and followed the pvc pipe where it came in from the outside and closer to the central unit in the attic I drilled a hole in the 90 degree elbow of the pvc and unclogged the pipe which was frozen from running so long. Then I covered the hole with silicone. no more leak coming from overflow
Dec 27, 2014 | Heating & Cooling
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Why does home central air conditioner will only cool to 80 degrees?
Because it is low on Freon. Do not run it low or the compressor wont be able to cool and you will burn it up. If it has run more than 1 hour in 90 degree heat the compressor is probably already damaged. Have a HVAC professional look at it, but if you were still using id plan for the worse, a complete replacement.
Jun 29, 2014 | Heating & Cooling
My deLonghi dehumidifier no longer dehumidifies. The device appears to be functioning OK but is not taking a drop of moisture into the tank. Previously, it filled in about 48 hours.
Hi, Soorry for the delay in the respones but I was stuck in a factory job the last few days.
When this happens usuall either the compressor is not running or the unit is packed with dirt. Can you tell me if you hear the compressor kicking on? I will look up this model and cover all the bases for you. The sysytem is slow on resposnes right now but I will keep on top of this with you till se get it going. Alsocheck the tank for a pluggage in the drain tube.
Feb 06, 2012 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
82 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
