Question about Sl Waber PowerHouse UPS System
Modem jacks do not work
I have connected the phone/modem cords to the In and Out connectors on the UPS system, as instructed in the owners' manual, but they don't work. Perhaps there it is a faulty unit in the UPS. What to do next. Thanks
There is a small (1"x3") board inside the unit that the phone line attaches to. This is what I can see without my magnifying glass: On this little board are soldered two fuses. Also there are two (transistors?) with only the outer legs being used in the circuit. They are labeled z1 and z2. (There's print there, but I can't read that small at this minute.) Maybe you can fix it yourself if it is out of warranty. -mike
Posted on Jun 09, 2007
    Problem Solver:
  • 7 Answers
Sounds that way to me as well. Call Waber and talk to tech support.
Posted on Jan 25, 2007
Trying to connect fax with my optimum (which is a triple play package) I also have wireless. The Wall jack cord is going directly into the modem. How do I connect the fax?
Your Optimum modem is acting the same as the phone company's input line to your home. The cord that goes from it to the wall jack is actually powering up all wall jacks it the home. You can:
  • Use any available wall jack in the home to cable up to the fax.
  • Split the output signal from the Optimum and connect to the splitter (may not work).
  • Run the Modem output to the LINE connection of the fax, and the EXT output of the fax to the wall jack (may not work)
Jun 28, 2015 | Office Equipment & Supplies
Tip
Linking your system connection to Air
TEMAB COMPUTERS ICT
You moving to the world of internetworking, as in you connecting your system with a dial up or modem so you can access the internet from your home, office and everywhere you may be the following are to be considered .
1. A computer. In order to use dial-up you must make sure not only that you have a computer but that it is going to work with your dial-up service. Some ISP's do not require that you install any software to get connected, so just about any computer would work. However, if they do require that you download their software or run a CD to start their service, you need to make sure that their software is compatible with your service.
For example, your computer may not have a CD drive if it's a compact laptop. Or perhaps you have an older operating systems like Windows 95 or 98. Many installations are not compatible with these older computers. If you have a Mac or Linux computer, you must make sure that the ISP will be compatible with it, or it might not work. If you are using the modem that came with the computer you have to make sure that the modem is installed or updated enough that it will not cause slow connections. Check with a computer technician if you are not sure there is a modem or that it's in good working order.
2. A modem. If your computer does not have a modem, or you wish to use a separate external modem, make sure that it is the correct type of modem. It must be a dial-up modem--broadband modems will not work. Also make sure that your modem is going to be compatible with the services you would like to have on your dial-up. For example, if you would like to add an Internet Call-waiting feature on your dial-up service, you need to have a V.92 standard computer. Otherwise you will not be able to be notified of incoming calls while you are online. Also, if the modem is not in proper working order, for example, it is missing it's latest driver software or has been damaged or corrupted, you will not be able to use it. Thirdly, if the modem is too old and does not have the latest standard, it may not connect as fast as a new one would, so if you know your modem is not V.92, you may need to get a new one so you can get better connection speeds.
3. A land-line telephone. This means your phone line must be an analog phone--cable phones, digital phones, and (usually) cellphones will not work. Dial-up uses analog phone lines because of how it converts and transmits information. It's just like a normal telephone. If you try to use dial-up on any other type of phone, you will get an error connecting because the modem cannot detect the analog dial-tone. Check with your phone provider if you are not sure if it is compatible to dial-up. Also, keep in mind that you will not be able to use your phone and the Internet at the same time, so if you wish to keep your phone line free for telephone calls, you may need to add a second line to your home. However, if you don't want two lines, simply add call waiting and caller ID to you land line and if you have a V.92 modem, you should be notified of incoming calls while you're online.
4. A telephone cord. This may sound silly, but some people do forget about this step. In order to have Internet through dial-up, you must have a phone cord attached from the back of the modem or the back of your computer to the phone jack in the wall. You might want to get a splitter so your phone line can share the phone jack with your computer, or you might be able to connect your computer to your phone or vice versa, using the "line in" and "line out" jacks on the phone or on the back of the computer.
Another important thing to keep in mind is that your telephone cord needs to be as short as possible. Any cord longer than 6 feet could affect your ability to connect to the Internet, or affect how fast you can connect. The longer the cord the more likely you are to have slow or dropped connections. Also, you may need to get a back up phone cord in case the cord you intend to use is damaged. If you buy a new modem, an extra phone cord is usually included.
After all that then you can move to meet an Internet service provider to have their modem or dial up. and their setup for the dial up giving to you. From there have a wonderful browsing and meting people
…………………connecting yourself Globally……………………………………
TEMAB COMPUTERS ICT
on Apr 30, 2010 | Computers & Internet
My d link router will not connect to the internet from my phone jack. I where I receive my phone and internet connections. What steps do I take to install to receive the highh speed connections?
The phone jack must be connected to a modem, which is then connected to the router via an ethernet cable. To connect:
1. Connect the phone cord from the jack in the wall to the jack in your modem of choice. Turn on the modem. 2. Connect a CAT-5 ethernet cable from the correct jack in the modem to the correct jack in the router. 3. If using a wired connection, connect an ethernet cable from the router to your computer. Otherwise, simply activate the wireless card of your computer and select from the available wireless networks.
Mar 11, 2011 | D-Link Office Equipment & Supplies
Cmment utuliser ce modem
  1. Save your work and shut down your PC.
  2. Connect the coaxial cable from the coaxial jack in your wall to the coaxial port on the rear of the modem. Turn the connector clockwise until the cable is firmly connected to the modem. Gently tug on it to make sure it is connected.
  3. Connect the appropriate cable, USB or Ethernet to the matching jack on the rear of the modem. Connect the other end of the cable to the appropriate port on your computer.
  4. Connect the modem's power adapter to a surge suppressor or a dependable wall socket.
  5. Press the power switch on the front of the modem to turn it on. Power up your PC. If you opted to use the USB connection method, you may have to install the appropriate drivers. Check your owner's manual for specifics.
  6. Launch your web browser http://192.xxx.xxx to verify Internet access.
Dec 04, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
We have no phone service at our home, since disconnecting and then reconnecting comcast box. We have a new computer and was instructed to disconnect modem and power cord for ten seconds to allow...
there should be a standard telephone cord that went from one of your telephone jacks to the comcast modem. that cord should be plugged in to the phone jack marked 1 on the back of the modem.
Sep 23, 2009 | Lands Phones
I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have made all connections re 'phone line up to connecting to tower - I can't connect as cable too short - what am I doing wrong? Should I be connecting via the back of the tower? I only have one...
You should have a modem installed in the tower portion of the system. It will have phone jacks. One is marked LINE the other is usually Phone. The Line or Wall jack plugs into the phone jack on the wall. if there is a phone plugged already, unplug it and plug it into the modem jack marked phone. Cord lengths are chosen to suit need. Radio Shack or the like have long cords if needed
Jan 05, 2009 | Computers & Internet
No Dial Tone on phones or modem
if you have a dial tone when your computer is not plugged in, then the problem ls with your computer[ a possible short in the computer] the phone cord to the jack, or anything in between such as a dsl modem.if you have dsl, be sure your ethernet cord [ that's the wider plug cord] is in the wider jack in back of the computer. it wont fit in the regular phone jack.if you have dial up, be sure the phone cord is in the regular jack not the ethernet port.[if you have one]
good luck
wg
Jan 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Modem connection
Your modem should have a RJ11 (phone) jack and a RJ45 (ethernet) jack. Phone line-in to modem RJ11. Ethernet cable from RJ45 to modem to router; maybe labeled WAN or modem port . Ethernet from any of the switch ports (or the only one avail, depending on your model) to you pc if it has a ethernet card in it. After that it's all up to the configuration.
Jan 04, 2008 | Computers & Internet
Sl Waber PowerHouse UPS System Logo
59 people viewed this question
Top Sl Waber Computers & Internet Experts
David Payne
David Payne
Are you a Sl Waber Computer and Internet Expert? Answer questions, earn points and help others
