I have an AKAI DGITAL INTEGRATED AMPLIFIER model NUMBER AM-M600 the connection at the back for the speakers has gone on one channel and i would like a replacement part please
  • Colin L.Swan May 11, 2010
    What DO you mean it's 'gone' on one channel??
    Is it broken or has that channel just lost it's output??
  • 71 Answers
Have you checked the wiring to the speaker that does not work and try swopping round the speakers to see if the failed one works O.K. on the other channel?
Posted on Nov 12, 2008
When the wires are placed in the slots in the back of the unit there is no sound from one of the speakers so i am asuming the contacts have gone in the unit where the wires go
Posted on Nov 07, 2008
Akai Reel-to-Reel Tape Recorder Model X2000SD how do I hook up the cables for sound? I can get sound through the speakers, but can't turn it up.
Most reel to reel tape recorders have "line out" in the form of RCA phono jacks. These are designed to be connected to an external amplifier. Some unit, however also have an internal amplifier and will output to speaker jacks that should be clearly marked. If your unit has such jacks and you cannot control the sound, your amplifier must be bad. Keep in mind, on most recorders, there are no internal speakers or output amplifier and the volume controls on the front are for recording only.
Apr 29, 2017 | Akai Audio Players & Recorders
How do I connect this system together to get it to work?
The manual for the amplifier and all the other units are here. Use the search feature in the top right with just the model number 'AT-5210'. Getting the items in the right order helps. The turntable obviously goes on top. The Amplifier goes in the middle and all the other units connect to the amp.
Akai AM U61 Manual Stereo Integrated Amplifier HiFi Engine
Jan 14, 2016 | Audio Players & Recorders
How do I connect my bose equalizer to my pioneer amplifier
The manual is at Bose.com.
In any question regarding connections the exact models of all parts in the scenario should be defined.
"Pioneer amplifier" is not unique nor revealing. Integrated amplifer? Power amp? Tape Loops available? Pre-Outs? What's involved as a preamp?
The key thing to know is that any amplifier channels driving 901's must not drive other speakers as the Active EQ severely modifies the Line Level source input. If the EQ (or any sound processor) is used in a Tape Loop on a modern multichannel digital-audio-capable AVR, ONLY 2-channel analog sources will function when the Tape Loop is engaged; and all downstream speakers will be affected by the processing. That's par for the AVR course.
Bose 901 use in multichannel applications (which I have) will require access to Pre-Amp outputs for the chosen channels (likely the Front) and you will need to get a separate amp for the 901's, placing the EQ in series with the chosen amplifier. I currently drive mine with a Carver MT-200T.
Sep 20, 2011 | Bose 901 EQ1915 Home Equalizer
I have a Technics SU-V460 integrated amplifier, and the left channel (speaker) keeps "dropping" out . I have to turn the volume right up in order for it to "kick" back in. Would this be...
There are three possible problems with your system. The first, and cheapest to fix, is that the wire connecting the left channel is faulty. To test this, unplug the wire from the back of the amp and put a new one in, then play some music BEFORE putting everything back into it's respective place. If the speaker doesn't cut out anymore, problem solved! Speaker wire is very cheap too. If the problem persists, try connecting one of your other speakers that you know works to the input. If that speaker cuts out as well, then the amplifier is the faulty component. That will cost some money to repair (between $50-$150 depending on where you go, excluding the price of a new amplifier). If the speaker you know is not faulty works when plugged into the left channel, then the only other option is that the original left channel speaker is faulty. This could cost between $25-$100 to get repaired, excluding the cost of a new speaker. It will not be as costly as a new amp, but will definitely cost more than a new speaker cable.
Mar 03, 2011 | Car Audio & Video
I have a faulty speaker will it damage my new 2 chanel amp
Yes it is important that the speakers you are connecting to the new amplifier is working good and having equal impedance inthe left and right channels. hence if you are confimed that the speakerr is faulty first of all replace the speaker or the speaker coils and diaphragm before you connect to the amplifier to be powered. Please also check if the network has any damage before taking an impedance check. This should be identtical to both the channels. If so you are ready to use your new amplifier. Hope this helps to guide you. Good day
Jul 18, 2010 | NAD C370 2-Channel Amplifier
How manny watts per channel??
I'm guessing the 200w are the Speakers maximum input, right?
Is the sub passive or active(=integrated Amp)?
If it's a passive sub:
If it's a 2-Channel Amplifier, you're talking about, you won't be able to connect all 3 - unless you can live with one speaker being significantly louder than the other or your amplifier going up in smoke...
As to the power required, if it's 250W PER CHANNEL the amp will blow your speakers, if it's 250W combined you may not be able to drive them to their absolute limit but they will be loud enough (they probably reach their db-limit with less than 200w but if they reach it with 200, you'll only get ~6db less than that with 125w per channel)
The Watt-numbers on (passive) speakers only tell you how much they can take before they are damaged, the relevant numbers for your problem are the efficiency (the unit is db/W or db/2,83V) and the maximum db-level (most floorstands can produce between 100 and 110 db at one meter distance)
If your speaker produces i.e. 87db/W at 1 meter distance (which is the standard measuring distance), it will produce ~97db at 10W, ~107 at 100W, etc. - unless it reaches it's limit before that. Most speakers can take a lot more power, than they need to reach their limit but they won't get any louder if you keep turning up the volume beyond that (they'll probably produce more distortions though, so don't)
As to the sub:
if it's passive, you'll need another amp (there are special amp-modules for subs, but any amp with enough power will do)
if it's active, you can connect it to the sub-out of your preamp (I'm guessing the PA Amp you mention is a Main Amp, not an integrated one) or your integrated amp via cinch (a tape-out works too)
OR you can connect it to the speaker outputs and than connect the speakers to the sub - in that case the sub is still NOT driven by your main amp but you can use it's crossover to separate low frequencies (--> SUB only) form higher frequencies (--> SPEAKERS only).
Most active subs can be connected both ways, if yours can't your stuck with one.
Rarely there is a third way, which only works if your sub supports it and if you either have seperate Pre- and Main-Amp or if your integrated amp has a Pre-Out and a Main-In (in that case in can be split into preamp and main amp)
IF you want to use your subs Crossover (which is good idea, provided it has one), you'll have to connect it between Amp and Speakers (works with allmost all active subs) or between preamp and main amp (works only with a few)
I hope this is helpful
Jan (Hamburg, Federal Republic of Krautistan)
Mar 17, 2010 | Radio Shack 250 Watt PA Amplifier...
Technics Integrated amplifier su-v85a speaker volume fluxuates and speaker left shuts down some times what is the problem?
test you speaker maybe there is a bad connection some where is the spk. box its self ,try changing speakers left to right .
it the spk. are ok open amp see all the connections within the amp .
if this dose not work contact me by mail: starilaz@net.hr
Oct 12, 2009 | Technics SUV500 2-Channel Amplifier
PreAmp to Amp problem
Sorted it. You have to put the plugs back in the PreampOUt/Main in or it cuts out the pre-amp.
Nov 18, 2008 | NAD C320 2-Channel Amplifier
88 people viewed this question
 Grubhead
Grubhead
