Question about Whirlpool GB9SHKXL Bottom Freezer Refrigerator
Whirlpool refrigator side by side(2 doors side by side)
When I plug in my refrigerator it turns on but does not get cold,every half second I hear circuit breaker clicking noise and refrigerator light turns bright and dim. I keep the refrigerator on the whole night but the refrigerator doesn’t get cold. Will you please tell me what cause is?
  • Mahbooba Nov 07, 2008
    I don,t fix yet. I need help to fix. This is 2 doors side by side refrigerator.
    Scholar:
  • 86 Answers
This sounds like the curcuit board has failed. No repair is able to be made to the board. Just replace the board and all should be fine..
Posted on Dec 29, 2008
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
THE REFRIGATE WORK WELL. TTHE FRIGE NOT COLD
its more likely its the cooling fan in back of freezer... it transfers cold air to fridge.. have it tested ..u should have a button on inside of door so when you close door it turns fan on for a bit..push button with finger (fridge side) you should hear a motor kick in.. if not its no good .
Feb 25, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
It freezes everything in both sides then warms up to 50 both sides it will get cold again it i push the filter reset button stay cold for a day or so then get warm again
IF YOU REFRIGE HAS DIGITAL COMPONENTS AND DIGITAL CONTROLS ,MAYBE ,,THE BAD COMPONENTS CAN BE MAIN CONTROL BOARD OR BAD TEMPETURE SENSORS..IF YOU REFRIGE IS UNDER WARRANTY CONTACT WHIRLPOOL TECHNICAL FACTORY SERVICES..
Feb 15, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
In door water line plugged or froze up.
Whirlpool water lines do not plug or freeze . Replace the dual water inlet valve behind the refrig , where the wall water line connects to on the refrig .
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrig is not getting cold. I hear a clicking
You have a bad overload / relay , which is plugged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 2220477 , and is easily replaceable .
Dec 06, 2009 | Whirlpool ED2FHSS Side by Side...
I have cold water but the ice maker is not working, there is no water in the ice maker
The refrig has 2 coils on 1 valve . 1 coil is for water dispensor and the other is for the ice maker . You need to replace the water valve behind the refrig . This is the piece that the wall water line connects to on the refrig .
Oct 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GB9SHKXL Bottom Freezer Refrigerator Logo
93 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
