Question about ASUS M2NPV-VM Motherboard
USB ports not working
Hi.. I have an ASUS M2NPV - VM based system with Athlon XPx2 5600+ processor and 2 Gb of RAM @ 800 Mhz + NVidia GeFeorce 8600 GT graphics card. It had been working fine for the past 1 year until I decided to open up and do a bit of self tinkering. I fiddled with the USB jumpers, and now none of the USB ports are working, even when I have set them back to the default position. Please do help, a PC without USB is just about useless.
  • sdaseem Nov 07, 2008
    thanx a lot Igorot, but it did not work. By the way, you asked me to disconnect the power chord before doing all this... was this just a precaution to protect me from electric shock or to save the motherboard from damage? Because while tinkering with the jumpers back then, I did not disconnect the power. Could that be the reason for permanent damage to my mainboard's USB ports? Please do help. Thakyou again.
    Problem Solver:
  • 19 Answers
Bro, go to the website of your motherboard manufacturer and download a screen shot of it then open your users manual and go to the motherboard overview. Observe the way all the jumpers has been connected and connect back all the jumpers that you have relocated to the way it is connected on the screen shot. ( by the way, disconnect the power cord before you do all of this ok?) Reboot your computer and check the USB detection on the Device manager. If it's detected then good but if not, uninstall it then reinstall it. I hope i was of help ! Good Day !!!
Posted on Nov 06, 2008
Asus m3n78-vm ram increase
Well, how much have you got? and are you running a 32 or 64 bit OS? For the Max ram you can fit to your mobo go to the ASUS site and look at the spec for your board. If you have a 32 bit os you cannot use more than 3.7 GB of ram, you can use as much RAM as you can afford or will fit if you have a 64bit OS.
Apr 04, 2013 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
M2NPV-VM - Fastest Compatible Processor?
Hello here is the cpu list:
http://support.asus.com/cpusupport/list.aspx?SLanguage=en&p=1&s=24&m=M2NPV-VM&os=&hashedid=HGTVnGv5nGahCYgK
I am glad to tell you that, the 945 cpu will fit your mainboard.
This is the fastes cpu, you can get for this mainboard.
Any other cpu that are not on the list, will not fit the mainboard ( it will not run )
But you probably have to upgrade the bios, to support the new cpu.
Make also sure the powersupply, is bigger than 300 watts.
I suggest a 500 watts.
You can also add more ram memory, for better performance.
Your mainboard supports:
4 x 240-pin DIMM, support max. 8GB DDR2 ram.
But a 32 bit system, only supports up to 3 gb.
Download also the manual here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=24&m=M2NPV-VM&os=&hashedid=HGTVnGv5nGahCYgK
By selecting your windows system.
Open the manual folder, and click on global for download.
Adobe reader, is needed to read content.
Hope this was helpfull.
Jan 30, 2013 | ASUS M2NPV-VM Motherboard
The Computer sometimes boots and sometimes not. If not, there is no voltage at the USB ports and the keyboard does not a thing, but the drives, both on sata and ide (or whatever they are called), are...
Hi, you can download a manual and drivers here:
http://usa.asus.com/Motherboards/AMD_AM2/M2NPVVM/#download
Please select your operating system.
Click on global for download.
The drivers needs to be unziped before installation.
Maybe your harddrive has a defect since it boots and sometimes don`t.
It could also be a virus.
Try to scan with these to programs:
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=mncol;1
http://www.superantispyware.com/download.html
Both programs are freeware.
Hope this will help you.
Aug 23, 2011 | ASUS M2NPV-VM Motherboard
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
Need specs
Systemax Ascent KMA3500 Desktop
Processor :AMD Athlon 64 X2 2.3 GHz
Installed Memory :2 GB (DDR2 SDRAM)
Operating System :Microsoft Windows Vista Business
Video Output Interface :PCI Express
RAM :2 GB
Max Supported RAM :4 GB
Installed Video Memory :128 MB
Supported RAM Speeds :800 Mhz
Hard Drive :160 GB
Hard Drive Interface Serial ATA II
CD / DVD :CD-RW/DVD-ROM (Combo)
Graphic Processor NVIDIA GeForce 6100
Integrated Audio Realtek ALC833
Networking
Networking Type Integrated 10/100 Network Card
Dec 18, 2009 | Systemax Ascent PC Desktop
I have procesour -- AMD 64 X 2 athlon motherboad -- asus M2A VM HDMI ram --- 4 GB ddr 2 (800 fsb) hd --- 500 gb which grafic card should i buy
well that all depends on the money you want to spend. Since you are using an Asus board and AMD processor I would reccommend a PCI-E 16 ATI card. Something like the http://www.newegg.com/Product/Product.aspx?Item=N82E16814102869 . Good luck!!
Sep 14, 2009 | Computers & Internet
Latest drivers
http://www.driverstock.com/ASUS-M2NPV-VM-driver-download/6-9-10277/index.html
thie above site should have the drivers copy paste into address bar check driver suitable download
Jul 09, 2008 | ASUS M2NPV-VM Motherboard
Boot error / No video out
Ajit,
The beeps are usually due to RAM or key board issues.
I would try by plugging it into a VGA socket of a monitor to see if it works.
Do you have heat problems? one suggestion is to try and reset the bios to default by moving the jumper on the mobo to do a hard reset.
good luck
Smeags.
Oct 23, 2007 | ASUS M2NPV-VM Motherboard
IDE ports in asus m2npv-vm & m2n-mx motherboards
hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Aug 22, 2007 | ASUS M2NPV-VM Motherboard
ASUS M2NPV-VM Motherboard Logo
288 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
