Question about Sansui DTV2760 27" TV
Red and green lines running through picture/ worse on black and white movies. T.V. is brand new and is hooked up to satalite
  • girls3renoug
    girls3renoug Nov 06, 2008
    thank you for helping. I will pass on information to see if it works
  • girls3renoug
    tv tuner? How do you fix that?
  • 905 Answers
Have you checked the picture size settings on the sat. ? may be to high a setting for the tv to recieve it properly
Posted on Nov 06, 2008
  • jason Nov 06, 2008
    if not there may be a problem with the tv's tuner
    it might just be some soldering ( from heat up of tuner) but if not then they will have to replace the tuner , the tuner its self really can't be fixed just replaced
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Have a maytag dryer with no directions. My cord has black, red, white and green wires - the green was screwed to the outside of the old dryer. This dryer has blue, red, and a white with green - the green...
Hi lasanaritchi...
The blue and red will be your two 110 volt lines (2 X 110 volts equals 220 volt) and the white one will be the neutral, green wire will be ground
Go to this link and see a picture of how to hook up your dryeer cord...
Please take time to rate me.
Jul 24, 2011 | Dryers
New plug changed from a 4 wire to a 3wire,won't run.
You have 3 lugs to hook up to. right lug gets red or black, left lug gets red or black. Center lug gets white. you can also hook green wire to center with white. Or hook green to the screw for the lug cover. What you did is correct.
Jun 14, 2010 | Frigidaire GLEQ332A Electric Dryer
I just purchased this tv. I had no trouble hooking up the satalite cable box but When I hooked up the dvd player the picture is only in black and white. How do I fix this?
Are you using component video (red/blue/green) rca jacks, or composite video input (yellow) rca jack? You need to match the color but watch out and do not get confused with the red and white RCA for audio.
Dec 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
Jenn Air cooktop has 4 wires Black, white, red, and green and my house supplies power with 3 leads white, black , & green. How are the wires hooked up to power the unit?
Old plug: green is ground, white and blace are both hot power. New cooktop: green is ground, WHITE is COMMON, black and RED are hot power. You are going to need an electrician to run a new circuit and plug for your new cooktop.
Aug 31, 2009 | Jenn-Air JED8230 Electric Cooktop
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Red picture
Assuming this is a TV with a picture tube and not plasma or LCD; I'm afraid that your picture tube is dying on you one electron gun at a time. From what you said your green electron gun is almost totally dead and the two remaining blue & green guns aren't far behind. Eventually you'll have no picture at all and I would estimate that to be about 6 more months but whatever the time eventually it will go totally black. These blackout periods will get longer and longer. The only way to fix your problem is a new picture tube but my will probably find it less expensive to just get a brand new TV set.
Apr 14, 2008 | Toshiba 36A50 36" TV
Help with ceiling fan
black with black is for fan motor from swith red with red is for light fan from switch blue goes conect to black thats power for the remote white wuth white thats streat line is call comun or negative green withe green that streat conection for ground protection
Dec 26, 2007 | Hampton Bay 46175 Cameron II Plus Ceiling...
Sansui DTV2760 27" TV Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
