Question about Zanussi FJS1225W Front Load Washer
Error code E90 on Zanussi zwf1631w - Zanussi FJS1225W Front Load Washer
  • beddows Nov 06, 2008
    error code E90 on Zanussi zwf1631w
  • Anonymous Dec 18, 2008
    Flashes up with E90 but cycle still finished
  • 54 Answers
SOURCE: E90 alarm code keeps coming
E90 appears to be caused by faulty connectors to the main circuit board which appears in the bottom right corner, if you're looking at the washer from the front with the lid off (looking down into washer). This is fixed by reseating, cleaning the connectors.
remove 2 screws at the back which secure the top,
push the top backwards,
unplug the connectors to the front panel,
vibrations due to unbalanced load may have loosened them,
push them firmly back in socket,
pushed the top (back to front, make sure a plastic tab seats properly to secure front part of top panel) in place and fastened the screws,
power on,
run the machine empty for minimum cycle - rinse only.
Good luck!!!!
Posted on Aug 19, 2008
IFIXALL
  • 868 Answers
SOURCE: error code E90
Remove the front panel and on the right side at the bottom youll find the main Circuit board.There is a connector on the harness that needs to be making a tighter contact.Make sure that all the wires that are in  contact with the circuit board are firmly touching.Sometimes using a pair if pointed tweezers and a sewing needle will be all you need to fix this .There is hope so dont go out and replace any parts just yet. .
Posted on May 22, 2008
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
SOURCE: Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Posted on Sep 16, 2008
kevin000
  • 1847 Answers
SOURCE: hi zanussi fjr 1254 w error code e90 what does
This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
Thanks
Posted on Jul 01, 2009
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded ยท E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Zanussi jetsystem 1400- error e90
    e90 is configuation problem reinstating configuration code may fix this(not easy to do) or electronic has lossed communication with display board. can be a bad connection between electronic and front display board. faulty electronic board the most likely.
    Jul 23, 2010 | Zanussi FJS1225W Front Load Washer
    Hi zanussi fjr 1254 w error code e90 what does
    Thanks
    Jul 01, 2009 | Zanussi Washing Machines
    Zanussi zwf1631w error code e40
    hiya
    E40 is the fault code for the doorlock, these are relatively cheap and easy to fit and if an independent (non zanussi) engineer was to fit it, you will probably be looking at around £40-£50 all in as a rough guide.
    hope this helps
    Nov 10, 2008 | Zanussi ZWF1440 Front Load Washer
    Sep 12, 2008 | Zanussi ZWF1440 Front Load Washer
    ZANUSSI ZWD1471S
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Apr 04, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
    Zanussi washing machine
    E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
    Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
    E90 Error Code
    Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
    Zanussi FJS1225W Front Load Washer Logo
    330 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
