Panafax UF-790 011 error code
I read about your fix and how you will need to trick the machine to see the paper tray. my email is bkolder@pocketnurse.com.
  • bkolder Nov 24, 2008
    we no longer have the machine.
    Sergeant:
  • 284 Answers
I left you a voicemail mr kolder on how to get in touch with me.. and what is it you would like me to email you.
Posted on Nov 24, 2008
ERROR CODE 041 ON PANAFAX
There is a fix for this. But only a Panasonic tech has access to the parts for the fix. The toner sensor underneath must be moved closer to the cartridge, you are not low on toner.
Jun 15, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Hello the Panafax UF 770 was donated to our school. We needed to figure out what this means: INFO. CODE=011? Can u help us please?
There probably a broken off magnet that sits in back of the paper cassette. If you have 2 paper trays, you should be OK without 1.
Jan 05, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
ERROR CODES 016 AND 010
Unplug
move ink cartridge to center
remove ink cartridge
knock off the mountain off dried ink where the ink cartridge normally sits
plug back in
press function 7
tel/dial key slowly 4 times
set
91
set
1 (for off)
set
stop
look in the bottom of the paper tray and push backstop flush up to the paper
Jan 03, 2009 | Panasonic Panafax UF-333 Plain Paper...
How to fix this code????
there is a little tab on the cassette that is broken. leave me a way to email or talk to you and this could be resolved
Sep 24, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Error 011 Panafax 585
The extension at the back of the tray has broken off, so the machine doesn't recognize that the tray has been put back in. Solve this by taking a piece of cardboard (business card works good), fold it up and insert it into the sensor at the far left where the extension would have gone when the tray is inserted. This will trick the machine into thinking that the paper tray has been inserted.
Jul 24, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Recording Paper Cassette
Error code 11 means that it does not see the cassette in the machine,. there is a tab on the back of the cassette that is broken . thats why your getting that code.
if you leave me a msg that you want to fix this i will contact you
Oct 09, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
74 people viewed this question
jasbo
jasbo
