Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
DEW indicator / battery
DEW indicator comes on and camera shuts down when operating on battery only. I took battery out, operated camera on DC (plugged into wall), and camera worked fine. No DEW indicator. I put battery back in, DEW indicator comes back on, and camera shuts down again. Battery is one that came with camera (Viewcam Z Li-ion battery, Model #BT-L226U). Camera used very little prior to this problem. Any help appreciated.
  • 12 more comments
  • Trent Weaver Oct 28, 2006
    DEW indicator now comes on, camera shuts down, when operating on both battery and plugged in. A "Sharp Authorized" repair shop advised that it would cost more to fix than to replace, due to shipping, and other bullcrap fees. Hate to replace it. Heck... I bought it new and only used it a couple of times. Would like to have it repaired at a REASONABLE price. Guess I could just throw it against a brick wall and watch it explode into hundreds of pieces, then send it back to Sharp!!!!!!!!!!!!!!!!
  • txrus Nov 20, 2007
    Same problem..dew indicator shows in both battery and AC power.
    want to resolder the DEW SENSOR, but how to OPEN camera (some screws somewhere?) My unit is QUASAR Model VM-L450.
    HELP!
    HELP!
  • Wyseguy Dec 17, 2007
    Same problem with the dew indicator. Sharp knows it's a problem with design and just don;t give a damn. It always happens when u are on vacation, or Halloween, or Christmas. Even in a house with dry heat where peoples skin cracks from the dry air, you get a dew sensor warning. If sharp doesn't step up and fix the problem, I won;'t, and noone should, but sharp again.
  • Anonymous Dec 27, 2007
    yes, my problem is the same frustrating one as all the others.
    The sharp viewcam Vl Z1 shows the dew light and then shuts down.
    I have not tried any repair options but it is off warranty so would be too expensive to repair. I surely will not buy ANY sharp product agin if they do not step up to the plate and repair this one.
  • mescrap Dec 28, 2007
    I, too, have the VL-Z1 and thought it was just a problem with my camera until I found this website. I got it to work for a little amount of time on Christmas morning and haven't been able to use it since. I've had the camera open since then, which is what the instruction manual suggests, and have had no luck!
  • Anonymous Jan 07, 2008
    Sharp knows this is a problem. If they have any care about the cost of good will with their customers they really shoul;d recall this item and have them repaired. I bought this when I had a baby. I've had to, on several occassions, run out to CVS and buy those expensive disposable video cameras.
    SHarp has a main headquarter in Mahwah NJ, where the Ford Plant used to be, I went there with the unit to see if there was a teck dept or someone who would speak to me about it. They gave me a list of outside vendors approved to fix tyhe unit (none of them Sharp).
  • sjxray Jan 19, 2008
    I have just recently purchased a new battery charger and battery for my Sharp. I lost those on a trip to Fl. a couple years ago. When I got those in my camera worked for a little. I left my camera outside overnight and then I had the dew warning. Should I just buy a new camera or try and fix this one, I don't have many repair shopd here. Does anyone know if Radio Shack can fix these problems????Thanks
  • niravj Jul 08, 2008
    Same problem. I am guessing that someone must have filed a lawsuite against Sharp for this horrible camcorder. I am pisssssed.
  • responsehamm Aug 07, 2008
    dew sensor sharp camcorder same as all the others
  • Sharpless Aug 17, 2008
    I had the same problem with a Sharp VL-Z5. (It was stolen in a burglary; serves the thief right!). My VL-Z7 is starting to act up with the DEW warning intermittently, but I bought it at Costco when they still had their lifetime satisfaction guarantee. If the problem becomes permanent, I'll just get my money back; it's the only reason I bought a Sharp camcorder a second time. Sharp truly did ruin their camcorder reputation by not offering to repair this problem. BTW, Solution 3 below looks like the best fix.
  • Anonymous Sep 26, 2008
    how the hell can I fix that DEW problem
  • takis56 Nov 23, 2008
    Same problem since I bought this piece of ****. I would never buy a Sharp in my whole life. Every time I am in a store and somebody looks at sharp products I "advertise" them.
    I wish I could do something in a search engine and every time somebody put the word "sharp" a pop up to come up and say DO NOT BUY SHARP.
  • megweh May 17, 2009
    dew in display and keeps ejecting the cassette
I opened tape area and battery area and ran a hair dryer behind the tape area on the sensor. Worked immediately!
If I hadn't read the other solutions on this page I wouldn't have known it was the sensor at all. I thought it was the batteries. Thanks u guys saved me some money!!
Posted on Feb 21, 2010
Hi
i simply removed the smaller coin shaped battery and the DEW warning disappeared. The camcorder had been sitting idle before this, so perhaps this is a contibutor to the problem.
Anyway i refitted the same battery and all is still fine, fingers crossed.
Deanyor
Posted on Dec 06, 2009
I just take the tape out, the battery out and disconnect the poer and firewire to make sure the machine is totally reset and it seems to work. This is on a VL-Z5 though
Posted on Sep 22, 2008
The solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittantly separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. The first problem I had with the camera was on a cold day, so it seemed to make sense. Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left. go to:http://omlets.tripod.com/sharpdew.jpg (if clicking on the link doesn't bring up the picture, copy and paste the link into your browser) Then, get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism. If your camera is like mine was, you may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't . If your eyes happen to be elderly like mine, I put on one of those magnifying head-bands. Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you. A couple of TEMPORARY fixes which have been reported: 1. Sometimes removing the small CR1216 battery which keeps the time display, and apparently also powers the dew sensor will get it working again, though most report it only works for a little while. When you remove the main battery, this little battery is located under a small plastic slide at the upper right of the compartment. 2. One person reported that out of desperation he put the camera in the refrigerator for 4 to 6 hours and that it began working again. 3. Another said: I wrapped aluminum foil around the contacts in order to lower the resistance and it worked. 4. And finally, another person reported cleaning the contacts with a cotton swab soaked with alcohol, got his camera working again. You may want to try some of these other reported fixes, however remelting the solder joints are more likely 'the long term fix.'
Posted on Apr 26, 2007
  • 1 more comment
  • makiniraq Jan 18, 2011
    Dude YOU are the man, took me 2 min to find my iron, 2 min to plug and heat, 2 seconds of contact on either side, and bam...Johnnys got his camera back..the world needs more people like you...third best solution my a$$.
  • silectech Mar 23, 2011
    i am in sri lanka,thank your advaice.i do it ,my camara i no working.thank
    chamika udaya
  • johnnysocko May 06, 2011
    Brilliant. Thank you. I was getting ready to trash it but resoldering the sensor solved the problem. I could not have done it without your photo. Thanks again.
We only film on hi-times and if your camara doesn't work then it is very frustrating so we where already talking about buying a new camara.
Fortunately I'm not afraid to try thinks and I tryed solution nmb. 3 (the soldering one) and it work (for now).
It was very easy to do so anyone with a soldering iron can do it, specially if you are, like us, about to buy a new camara and for that you have nothing to lose but only to win
Thank you very much, for us it was very helpful
Hi I'm from Philippines I have the same problem with my VL-Z1 camcorder I bought long time ago in Hong kong sometimes it has dew message and sometimes not when I leave for a long time without using it. And I found a solution that I read from it's manual just leave the dv tape cover open for a long time and presto you can use it again without the annoying Dew message. Hope it helps.
Posted on Dec 09, 2008
Blow dryer was by me also but for 30 minutes and worked. Next time it happened again.
Anybody can help me take it apart? I don't know how to get to the sensor.
Thank you.
Posted on Nov 24, 2008
**** sharp shame thier brain aint like their name never by their **** again
I have the sharp ZL-V1 and have the same problem, but is nothing to do with the battery, all i do when it comes up dew is take the tape out for a couple of minutes and then pop it back in then it seems to work again.
Posted on Jan 31, 2008
I removed the tape and hit the internal mechanisms with a blow dryer set on "low" for about 15 seconds. Camera works fine now! Blonde logic, LOL.
Posted on Jan 06, 2008
Same problem, I will never buy anything from Sharp again.
Posted on Dec 22, 2007
This is the worse camera i have ever owned. Sharp wont support it because they know its a crap camera. I will never buy any sharp product ever again. I dont usually check the internet when i buy electronics for problems before i buy, but know i check everything on the net before i buy.
Posted on Jun 05, 2007
You are a smart guy.
Posted on Mar 16, 2007
I have a Panasonic NV-GS 35 digiatl video camera. 'Dew Indicator' error is coming . How can I remove this problem??
hi,dew means you got humidity level to high inside the camera
,press eject,removed the battery and try to use an air dryer an blow air inside the mechanism
thats where the dew sensor is located , for few minutes the let it cool down in a dry place
thats should reset the sensor system, if its not work that mean you will have to
replace the dew sensor.
hope that will help you,thats all i can do from here.
regards Alan.
Dec 25, 2010 | Panasonic NV-GS35 Mini DV Digital...
What doe DEW mean? The "DEW" sign keeps coming on and then shutting off..
DEW sign indicates high humidity level inside the camcorder. What you experiencing has nothing to do with humidity, It is a faulty connector on a junction board. Sharp has fix for it.
Jul 12, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
Bypassing dew sensor on a Sharp VL-Z7 mini DV
- the solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. The first problem I had with the camera was on a cold day, so it seemed to make sense.
go to:
Jan 25, 2009 | Sharp Viewcam VL-Z7U Mini DV Digital...
Sharp VL-Z900
The solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
Jan 15, 2009 | Sharp VL-Z5 Mini DV Digital Camcorder
My sharp video shows the word dew on the screen then shuts down what do i do to correct the problem
do not operate your vcr in damp conditions or move it between rooms with different temperatures without letting it get used to new temp before switching on
do not switch of at the wall socket as vcr's have a little low power heater inside that keeps dew (dampness) away
Oct 14, 2008 | Televison & Video
In your owners manual on page 52 you will find a list of authorized service centers. Give the one in your area a call. Give them the brand name and model number of the camcorder. Tell them you are having a problem with the dew warning coming on while using the camera with the battery. They should be able to help find a answer to this problem.You can also call the panasonic customer support telephone number at 1-800-211-7262 between the hours of 9am-7pm EST. Give them the brand name and model number of the camcorder and ask them for help with the problem of dew indicator coming on while in use with the battery. I hope this information helps you with your camcorder problem.
Nov 20, 2007 | Quasar VM-L450 Camcorder
Closing itself down DEW
camcorder when turned on flashes in red DEW and closes it self down. i have taken all the batteries out and replaced sometimes after a few days the camcorder will work then DEW will rea ppear and shut itself down
Nov 02, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
I get the DEW indication and cam shuts off
try to dry up your camera using electric hair blower drier, dew is present inside your camera, but dont overheat the unit, place your hand between drier and cam to make sure you are not overheating it. if the trouble is still there, the sensor is defective and you need pro fix.
Sep 28, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Dew detector please help me
You would have to replace the dew sensor which is a device in close proximity to the video head which shuts down the camera to avoid damage when moisture is detected at a high level inside the camera. Sounds like your sensor has changed values and triggers at too low a level. If you are not familiar with this kind of technology you should take it to a repair shop. The repair should be less than $100 US. Two websites which give free estimates are http://www.camcorderrepair.com and http://www.videotech.com Good luck.
Jun 04, 2006 | Panasonic PV-L759 VHS-C Analog Camcorder
Panasonic camcorder (NV-DS65) - Dew Indicator Problem
I found this on another site, but it WORKED great for me, and was a VERY easy fix, so I suggest everyone to try it before you go disassembling your camera. I know this sounds very stupid, but it actually somehow fixed my problem, so everyone should give it a go:
1) Turn the camera on.
2) When the dew icon is displayed, take off the battery and then hit/smack the spot on the camera where the battery goes a couple of times (not overly hard, but with some force).
3) Put the battery back and see if it's fixed. If it isn't, repeat the whole procedure. It took me about four tries but now miraculously my camera seems to be working, for the first time in about 3-4 years!!!
NOTE: I don't know what the exact "fixing" spot is, so I just hitted different places of the battery spot (both the upper and lower region). Take it easy first and don't hit too hard, see if it works and try again putting more force if necessary. I still can't believe this solved the problem, wish I'd tried it back when the problem first occured!
NOTE #2: I think this fix will probably also work on some other Panasonic cameras with the same dew problem - in fact, I think the guy who originally came up with this solution actually had a different camera model than I do.. I know it's a late reply, but hopefully this helps at least someone!
Sep 06, 2005 | Panasonic AG-185 Camcorder
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
3,558 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
