Laptop cannot connect to internet outside company domain using wifi at home
It connects to internal wireless and works fine, but from home it will not access internet. It identifies and successfully connects to wireless router, but no internet access.
It's recently happened to a few laptops in my company so I suspect it's a group policy that I may have inadvertantly pushed down.
    Scholar:
  • 53 Answers
Typically at home you don't need any proxy settings configured within internet explorer. often in a work environment proxy settings can be applied.
if you think thar you have access to modify the settings do the following;
right click the IE7 (same for IE6) icon on your desktop select properties and select internet properties on the dropdown list.
left click the "Connections" tab
left click the LAN Settings button
deselect all of the ticks (most importantly the Proxy server part)
left click OK
left click OK
then open up IE normally and see if this has worked.
note of caution though; if as you suspect group policy is pushing the settings, next time you logon to the company LAN your changes may be lost and you will need to remove the ticks again.
also if you still get no joy try leaving the Automatically detect settings ticked with the proxy part unticked.
Posted on Nov 06, 2008
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
Only one device is having internet issues
Have you checked the IP settings on your internal network. It sounds like you have 2 identical IP numbers.
May 29, 2017 | D-Link DIR-615 Wireless Router
Can't start my wireless modem
I think the problem is you cannot connect to the internet wirelessly using your laptop. The problem may lie in the modem or in the laptop itself.
First you need to isolate the problem. That is, determine if the laptop or your modem is the one that has the problem. If you can connect to the internet using your laptop in someone elses home network or free wifi outside your home, then the problem is your modem. BTW, modems don't have the capability to connect wireless devices to the internet. You need a wireless router. If what you have is a router, you're on the right track.
If your laptop can detect your home network, try connecting to it. If you're getting an error, call your Internet Service Provider. They should be able to help you fix the problem. Also, try updating the driver of your laptop's wireless card. You can do this by hardwiring your laptop onto your router, go to device manager, right click on your wireless card, then hit update driver. If nothing works, call your laptop's OEM.
Sep 28, 2011 | Lenovo ThinkPad R60 with Wireless Wide...
My Acer laptop wireless not working. It was
first network setup wizard then u try the internet through wireless
Nov 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
I can't connect to the internet on my ACER Aspire One aod150-1920 netbook running XP. I am connected to my home network (wifi, excellent strength) but IE, Skype, Mcafee won't connect. Laptop and desktop...
Most Acers use an IPN2220 Wireless card. If yours does and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable
Nov 02, 2009 | Acer Aspire One AOD150-1920 Netbook
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
Cant See Preferred Wifi or Connect,
Having gone so far, I think the next thing you should do now is to get to the wireless properties and then assign an IP Address, Subnet mask and the Default Gateway for the Internet and you will be amazed to be connected. If you have not disabled and enabled the wireless device you may do that before proceeding to the step above. The pc should be restarted after the exercise ok. Good luck
Jun 02, 2009 | Computers & Internet
Can ping but cant connect to the internet
you may have to go to your routers ip address and see if you cant configure it to work or maybe your router can only support a certain number of wireless devices.
May 06, 2009 | ASUS Eee Pc 1000Ha 160G Netbook
Medion MD--96015
Are you trying to access your laptop (which you leave at home) from another computer away from home?
  • If so, head over to www.logmein.com and sign up for a free account. It's a wonderfully easy way to get remote control of your machine from another location without worrying about the networking.
Are you trying to use your laptop on the road and still have Internet?
  • If so, you will need some method for your laptop to connect to the Internet. If your laptop has a wireless WiFi card you can go to some location that has wireless internet. Many locations (such as hotels, cafes, and coffee houses) have free or paid wireless Internet service.
  • You can also get a Wireless Aircard as your friend said. These are a fee-based service from cell companies such as Verizon or Sprint that give you a card that plugs into your laptop and uses the wireless cell network to give you Internet access.
May 21, 2008 | Computers & Internet
Computers & Internet Logo
679 people viewed this question
David Payne
David Payne
