Question about Fellowes Powershred 320C Shredder
Fellowes P400C shredder
It will work in reverse and goes on in forward but sounds rather rough and won't take paper. Sounds like out of alignment.
    Scholar:
  • 102 Answers
Actually this is more than likely a broken gear. Unfortunately we no longer have any replacement parts for this machine.
Posted on Feb 22, 2008
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
Motor problem
It sounds as if the SafeSense is improperly shutting of the forward sensor. Call Fellowes and see if they can help.
If you do not have the manual use the link below:
Aug 18, 2014 | Fellowes 75cs Cross Cut Shredder -...
Shredder will go on reverse but not forward
I have one like the one pictured. UNPLUG THE UNIT, USE GLOVES THE WHEELS ARE SHARP. Take another look at the underside see if the old paper is compacted if so, use an ice pick to pry the paper loose but be careful. Another item you will see 7 holes those are screws. Use a phillips and remove the screws to expose the working parts. Look for paper jams etc. move the wheels by hand, add a little WE40 or lite oil. Hope this helps.
Apr 09, 2014 | Fellowes P400C-2 Shredder
Shredder will not take paper to shred. Will only operate in reverse.
look inside entry for paper and find the sensor switch. Make sure it is free and not bound up. If so unplug and clean out. GL
Dec 22, 2010 | Fellowes P400C-2 Shredder
Shredder motor will run in reverse, but not
Sounds like a bad or dirty switch you can try to clean it with alcohol ( the switch that gets activated by the paper)
-Carl
Jul 06, 2009 | Fellowes Powershred 480 Shredder
Fellowes Paper Shredder P70CM paper jam
Clean the upper and lower sensors with a cotton swab moistened with rubbing alcohol.
Jun 21, 2009 | Fellowes P70CM Shredder
P400c-2 fellowes shredder only runs in reverse no power in forward. everything mechanical is working fine.
I just had the same problem. I called the 800 # they asked for proof of purchase to replace if 1 year old. I did not have it so...... I took it apart ------ unpluged ! Only to find all gears are fine, service dept. said gears cause this problem, not so with mine. Remove top by pulling of base remove 6 screws on under side, played with the switch inside a bit and, it now works, do not know how long but for know it does. My opinion is the relay gets dirty, and you cannot clean it without talking whole thing apart.
Apr 21, 2009 | Fellowes P400C-2 Shredder
Motor on / Blades don't move.
Sounds like the internal gears or drive shafts are either broken, or out of alignment. Not exactly something that can be easily fixed usually. Hopefully, it's still under warranty?
Mar 13, 2009 | Fellowes OD700C Shredder
Fellowes Powershred 320C Shredder Logo
182 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
