Question about Philips 60PP9753 60" Rear Projection Television
No HD picture from AV4 or AV3
I have sound when connected to either input but there is no real picture. There is "scrolling color lines" no actual picture scrolling. Problem started when the power to house was going on and of during a t-storm. Picture works fine from AV1 and the side input. Have tried new DVI cord and other video cables for AV 3, no luck. I tried unpligging the tv for a few minutes, no help. Then unplugged the tv overnight, no help.
    President:
  • 3,130 Answers
You power supply has a problem in it. If the electric ever starts to go on and off again, you really should disconnect the main to the house or purchace a standby power supply for the TV set like the ones peeps use for their computers. They are inexpensive these days and they really do work and save lots of money. Now about the TV set. Without a service manual and the know how to work on solid state electronics and printed circuit board, you should seek out the assistance of a service person for this type of repair, unless you do know how to use a multimeter and read a schematic diagram. Good Luck PS Please dont forget to rate this thread.
Posted on Oct 28, 2006
What does AV1 mean on a SAM*TRON TV mean? How do I get rid of it?
av 1 is the source input for the tv
there should be av 2, 3 4 etc and each one isa for a different input item
for example av1 is for the tv -aerial , av2 may be dvd input , av3 may be x box, av4 home theater
how to get rid of it . click on exit or ok
Sep 30, 2016 | Televison & Video
Need the manual to find out how to setup AV3 & AV4 as Component input, or if it is compatible with standard component input. Does not seem to work
Well, lets start here first. I would like you to look at the input jacks for a/v3 and a/v4 and see if they are color coded RED-GREEN-BLUE. or if they are just YELLOW-RED&WHITE (audio). If they are RGB then just buy RGB cables at your local Best Buy. If any are just Yellow and Red & White then those are just regular composite video the same as the old vcr's. You can't make A/V jacks work like RGB component jacks.
Dec 01, 2010 | Televison & Video
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
I Just connect My pc via 15 pin RGB cable to LG 32R50xx lcd tv,it show the picture but no sound. Than i connect the audio cable to the tv use 3.5mm j. it only has sound when I use input and select AV3 but...
You probably need a audio cable that runs from the pc audio out to the TV audio in. Radio shack has them so do a lot of hardware store and best buy.
Aug 08, 2009 | LG 42LG30 42 in. LCD HDTV
Problem with AV 4 input only.
Check to make sure your settings on your PS3 are set to the RED BLUE GREEN (component) input.
Mar 25, 2009 | Philips 55PW9363 55" Rear Projection...
Adding a hd set top box to 55pp8620
hdmi id the best way to go
see if it is high defition input "HDMI" or s-video or av hook ups are not high def
Mar 15, 2009 | Philips Televison & Video
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
Inputs for HD on tv
Do you have the composite cables(red, blue, green) hooked up too the back?
Jan 09, 2008 | Philips Magnavox 51MP392H Rear Projection...
HD input
On the Magnavox projections, only one of the inputs supports hight than 480p input IE: 720p, 1080i. Make sure it is the correct input.
Dec 17, 2007 | Philips Magnavox 51MP392H Rear Projection...
Composite and s-video inputs stopped working
You may have shifted the input board a little while replaceing the IC's. Double check every plug and connector, not just by visuale inspection, but by going and removing and replacing every connector. I have had problems like this in the pasy and have learned the hard way, everything is not as it looks. Good Luck
Jun 04, 2007 | Philips 60PP9202 60" Rear Projection...
Open Questions:
I own a Samsung LN40C630K1FXZA TV with no picture but has audio and backlights. I need help determining what boards to replace. I tried to watch some tutorials posted on YouTube and have the following information. The TV was starting to have an issue that while watching it the picture was seeming to get a little jerky like it wasn't refreshing fast enough. It wasn't always noticeable and I initially though it may have been a signal issue with our cable. Eventually we turned on the TV one morning, the picture came on and then disappeared after 2 or 3 seconds but we still had audio. I tried to pull up the menu screen and that was not visible. I performed the flashlight test and there are images visible with the light. I removed the back cover and took pictures of the attached boards and also saw that the backlights seemed to be working but did seem like they were not quite a constant consistantly light. They never completely extinguish but do seem to fluctuate in brightness slightly. I did not see any visible issues with any if the capacitors being swollen or blown and did not see any apparent burnt components or boards. Below are the readings I got from one board but I was not sure where to get the readings on the TCON board. Main PBA readings CN201 1. 18v. Actual 13.1v 2. Sw. Power Actual 13.1v 3. 18v. Actual 13.1v 4. 5v. Actual. Falling to -1.6mv 5. 5v actual. Falling to -1.7mv 6. 5v actual 5.15v 7. 5v. Actual 5.15v 8. ground actual 13.1v 9. Ground actual 13.1v Any help would be greatly appreciated so I can buy the right parts from you. Thanks, Chris
Jan 19, 2019 | Samsung Televison & Video
See all Philips 60PP9753 60" Rear Projection Television Questions
Philips 60PP9753 60" Rear Projection Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
