Kenmore Washer 80 Series - Water cut off
The water does NOT cut off when it reaches the required water level and the water has to be turned off manually.
Would also like to find a Manual for this machine.
Thanks and have a GREAT Day!!!
There is a vacuum hose hooked to your water level adjuster. If that hose falls off, which it sometimes does because there is no hose clamp, the washing machine will not know how high the water is and will continue to fill. I found this out after starting my wash before bed and waking up at 6:00 to ankle deep puddles all over my house.
the fix: open the gauge panel by taking off the plastic covers on each side and unscrewing the bolts under the covers (one per side) then the gauge panel will rotate up and allow you access to the hose and other gauges
if the hose is still clamped on check for holes in it and if no holes then you may want to replace the leveler guage
Posted on Aug 23, 2009
Where is the reset button for a kenmore 80 washer wont stop filling water level
If this is a top loader then the vacuum line has come off of the dashpot or the water level switch is broken. UNPLUG the power-Standing in front of the washer, pry off the plastic trim strips on the left and right of the dash (control panel) Now you'll see a screw at the bottom where the strips mounted, remove ans KEEP the screws, now the dash will lift up and fold back, giving access to the parts.
Aug 17, 2014 | Kenmore series 80 Washer Motor 3363737-
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Have a kenmore 80 series washer that does not cut off water after tub has reach it's level and overflows
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds like a defective Water level Switch:
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the following for how to access the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=400785c7cf87579d23b319fdde9a00ce
The following diagram may also help locate the components.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=138
Mar 28, 2010 | Kenmore Washing Machines
Water not cutting off at full level and leaking-Kenmore washer 80
The water lever sensor/switch is not working and needs to be replaced. IT has a air tube that senses the water lever by pressure. It the tube is clear then the switch needs replaciing,, If they is a clog, clear it and retry before replacing it.
Feb 06, 2010 | Washing Machines
The washer is filling with water but not stopping @ it's right cycle. It overflowed last night. If you could help it would be greatly appreciated. Kenmore 80 series
Check the water level switch. This diaphragm like device has a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, so does the pressure on the air in the tube, and when it reaches a certain level, it activates the switch to turn off the water and signals the timer to start the appropriate cycle. Look for any damage to the tube and make sure it has no obstructions in it. The switch can be tested for continuity using a multimeter or ohmmeter. A lack of continuity indicates a bad switch. Hope this helped and best wishes.
Aug 20, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer will not stop filling up
one of three things,inlet water valve bad,water level hose came loose or water level switch is bad,check all tree and let me know-mike
Apr 14, 2009 | Kenmore 24902 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
241 people viewed this question
Top Washing Machines Experts
