Question about ViewSonic P815 21" CRT Monitor
Blue vertical line
Hi. I have a 20" moniter that has a blue vertical line just to the right of center. It runs top to bottom. I only see it when the backround is black or when watching a movie. Any way to get rid of this? Thanks in advance
4 Suggested Answers
  • 2961 Answers
SOURCE: "OSD lock" in blue box
The monitor will have the on screen display setting as locked, look at the monitor settins buttons, where you set the brightness etc.
Posted on Feb 14, 2007
  • 80 Answers
SOURCE: my lcd monitor got a blue line on the right side
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them. and
Good Luck!
Posted on Jun 13, 2010
  • 11361 Answers
SOURCE: I have a blue vertical
That can be bad TFT driver on the LCD panel assembly, new panel will be needed it, you can check the connection between the logic board and the LCD panel first. Also inspect the caps in the power supply as well. read more here:
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors:
Capacitors kit: he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 02, 2010
  • 11361 Answers
SOURCE: I have 2 vx2235wm, just over a year old. Within a
Solid vertical line means you have bad LCD panel due to failed TFT driving circuits.
This VX series are not built as well as the old Viewsonic used to be.
Posted on Oct 17, 2010
0 characters
1 Points
All of a sudden I have blue line vertical right of center
Vertical lines on an LCD screen are, as a general rule, not good! Your screen is heading for the drain!
Jul 17, 2010 | Sceptre X 7 Komodo II 17 in. Flat Panel...
There is a thin blue vertical line, top to bottom that appears on the right hand side of the monitor,
it is a dead line much like a dead pixel the screen will need to be replaced
May 08, 2010 | Computer Monitors
I have 2 lines running down my monitor screen. One blue, one green.
They are vertical lines running from top to the bottom, then it can be loose ribbon cable or dirty connectors, or failed LCD controller board (part of the LCD panel assembly, whole panel will have to be replaced).
See pictures:
Apr 03, 2010 | HP W2338H Monitor
Demagnetize computer monitor
It looks more with screen resolution problem, if it is new then the best option is get it replaced.
Dec 12, 2007 | HP mx705 17" CRT Monitor
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computer Monitors
Open Questions:
See all ViewSonic P815 21" CRT Monitor Questions
ViewSonic P815 21" CRT Monitor Logo
26 people viewed this question
Top ViewSonic Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer Monitor Expert? Answer questions, earn points and help others
