Question about Garmin GPS
My Nuvi 310 can't find satelites.I have re-booted several times but without any Joy.the re-boot also locked on the map display The Mall in London.!?
  • Garmin Master
  • 2,130 Answers
There are a few things you can try to restore satellite reception.
1. place your finger over the lower left-hand corner of the screen and hold it there
while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings. This will clear some of the memory allowing your Nuvi to collect new satellite data. Your Nuvi should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
Make sure the antenna is up and that you are outside. On the main screen, you will see a satellite bar graph in the upper left-hand corner. Touch the bar graph and you should get a satellite map, showing the satellites. If your Nuvi's receiver is working ok, you should see horizontal hollow bar graphs appear on the right. Eventually they will turn solid blue. This indicates they have downloaded the proper data from the satellite. When you have (4) solid blue horizontal bars (4 satellites), you will see the top panel begin to show improved accuracy and your Nuvi will then work as it should. This entire process make take 30 minutes or less.
If you don't see any bar graphs, your Nuvi may ask you severl minutes later, if you are indoors. If your outside, select no. It will then ask you if you have moved 1000 miles since your last use. Select yes. This will cause your Nuvi to start looking for
satellites, trying to locate your new position.
Now, if you still don't see any bar graphs, then your antenna may have a problem. There is a known issue with the Nuvi antenna where a part has failed, causing the Nuvi to no longer use its internal antenna and it's now always looking for an antenna at the external antenna port (the gold connector on the side of the Nuvi antenna). If you have a piece of small wire, a couple feet long, you can insert that into the center lead of the external antenna jack. Most likely, you'll begin to see bar graphs after a few minutes and your Nuvi will lock.
I haven't been able to identify yet, which part has failed. I am working on that.
However, if the piece of wire works, you can always go on eBay or a retail store and
purchase an external antenna for your Nuvi. They are magnetic and can either stick to your roof or any metal surface within your vehicle.
Here's another way to determine if your antenna has failed and will have to be replaced:
At the main menu, pres on the "wrench" symbol. Then press the "gear" symbol and then press "about". There is a field marked "GPS S/W". There should be a number next to it. It may be "2.9" or "3.0". That is good. That tells you that the main board in the GPS is communcating with the antenna receiver. If you see "0.0" then your antenna is defective and there's no way to repair it other than replace it.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Nov 06, 2008
Hello Was hoping to get a video on how to
First, a freezing problem or lock-up during boot-up has nothing to do with the LCD display. If the screens shows a graphic, such as the Garmin logo and without lines or splotches, then the screen is fine. Lock-ups during boot-up are caused by corrupted firmware or maps or a corrupted flash drive. All of which can be resolved without taking the unit apart. The battery has nothing to do with it either. If the unit locks up while connected to the car charger, then the battery is essentially being charged and not powering the unit. I can't see your board but if you pulled the ribbon out of the board, you may have damaged the locking latch that holds the ribbon in place. The locking latch is a thin white or rust-colored strip of plastic on a hinge. That hinge should be up when sliding the flex cable into the connector, then the locking latch is pushed down toward the flex cable until you hear it click. The flex cable should be secured at this point. If you have busted the locking latch off, it is game over for your Nuvi. More info on booting issues can be found here:
Sep 25, 2013 | Garmin Nuvi 255 GPS Receiver
Reboot the Nuvi 360 to "Mass Storage Mode"
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
Tray on PC (Lower Right)
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
Sep 30, 2008 | Garmin n vi 360 GPS Receiver
My Garmin Nuvi 1490 LMT returning to normal functionality after doing a map update.
Common problem caused by a failed map or firmware update...or both.
Corrupted map or firmware files prevents the unit from booting normally. More info on boot-up problems here:
Apr 07, 2013 | Garmin Nuvi 1490LMT Nuvi 1490 w/ Lifetime...
Garmin 1340T boot loop issue. The unit
Unfortunately, there isn't an easy solution for the Nuvi owner as it requires a custom piece of firmware to flash the unit to make it at least boot. This problem is often caused during a failed firmware and/or map update.
It sounds like a file was corrupted. Sometimes it is better to connect the unit up to a PC, delete the old map and then proceed to install the new one. There are so many issues with memory space causing failed downloads and corrupted files.
If the map file is missing, the unit will boot-up OK, it will just say "Map data unavailable" but if the map file or associated map files are corrupted, it can cause the unit to crash. Your PC won't recognize the Nuvi because you have the reach the main screen before the data communication mode routines are accessed.
We've had some success in restoring some of these units by flashing a "fix" firmware in "pre-boot mode" that doesn't try to load the map or map associated files. This should then allow the unit to boot. Once the unit boots, Windows will recognize it and then you can copy a map over to it from the PC. Reboot the unit and then flash it with the standard firmware.
- Jim
Feb 23, 2012 | GPS
Hi my name tony i need to update my maps on my garmin 310
Garmin offers two kinds of updates on its website: software updates are free. Map updates are not. You'll need a USB cable to connect the Garmin to your computer. Then go to
On the web site, first register your product. Then look for "Support" and follow their instructions for updating your software. After you've done that, look for "Maps" on the menu at the top of the screen. You can either purchase updates one at a time, or buy a lifetime (of your device) subscription. By the way, maps are huge files, so plan on it taking several hours to update your maps even with a fast internet connection.
Apr 18, 2011 | Garmin nuvi 310 Car GPS Receiver
Can i get free up dates on maps on gamin nuvi 310
The only time garmin gives free map updates is if a new map becomes available within 60 days of the first time your satnav accesses satellites. If you think you're entitled to a free update go through the update procedure as described at If there's an update available click on get update. If you're entitled to it free it will bring you to the download page. If you're not entitled to it free it'll bring you to the payments page.
Feb 20, 2011 | Garmin nuvi 310 Car GPS Receiver
I've updated my map for garmin nuvi 310 through malfreemaps but it did not work well. The map did not display as detail as they preview. I also lost the guidance voice. And my car picture keep off the most...
It sounds like you may have wiped out the Garmin internal maps with the malfreemaps and they aren't compatible with your unit. You'll have to send it in to Garmin to have them reload the units software and maps.
Oct 14, 2009 | Garmin nuvi 310 Car GPS Receiver
No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Feb 28, 2009 | Garmin nuvi 255W GPS Receiver
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
GPS Logo
308 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
