Question about Sony Playstation 3 (PS3) Console
PS3 freezes Had the system for just one month and shut it down to go to work. When I turned it the next day the I got the pre-system screen with that wave through it. I went to the PS3 help site and did everything they sugested and still can get the system to un-freeze. Short of taking it back to where I purchased it I wanted to see if other had and/or was having the same problems and pick your brain to see if there is a solutiuon out there...any and all help is very appreciated!
There are two solution you can try, it is unlikely there is a hardware fault.
1st soloution try installing all latest updates from system updates.
if this does not work go to system settings> backup then follow the instructions to back up your data i advise using a memory stick or portable hard drive.
When this is done go to system settings and select restore ps3, follow the instructions and your data will be erased, your ps3 will be restored to its factory default with the operating re installed. When your ps3 reboots install the latest updates.
Then try your ps3 out to see if it freezes, if all is fine go to system settings> back and choose to restore a previous backup, you will then have all your saved data back. Then you can enjoy your ps3 :)
if this does not work i advise contacting sony for more advice.
Posted on Nov 06, 2008
PS3 keeps freezing with colorful pixels. How can I fix this?
You need to use a vacuum and suck the back out or blow it out with air . While power is off on PS3 turn power on holding down the eject button it will blow it self out .
Sep 20, 2014 | Sony Playstation 3 (PS3) Console
For the last month or so when logged into facebook on my playstation 3 it takes fotever to load anything and freezes my system when i shut it down?
Here is why!!!!! The PS3 is NOT a very good computer, and trying to run web pages like Face Book on the PS3 is very buggy. Sometimes it will work, others, it won't. The reason being, you can not update Adobe Flash on the PS3, and therfore, not able to run a lot of the flash objects found on the page.
Aug 05, 2014 | Sony Playstation 3 (PS3) Console
My ps3 system will turn on, get the green light, but don't get any sound or picture. it's not my av cord, cuz i am using my ps2 on it now. my ps3 was working just fine and then my screen just scrambled and...
Interesting problem. I recommend trying a reset of the video card. It's pretty easy, Sony has the instructions here.
Except for the scrambling and freezing, it sounds like an issue I had recently with my own system. Give this a try and please leave a comment on weather it worked or not.
Dec 14, 2010 | Sony Playstation 3 (PS3) Console
Possible overheating
The PS3 has an automatic feature to shut down the system once it acquires overheating. The fans installed vary on how much heat is being generated by the system to cool it down. If the screen freezes occassionally try to set the resolution to a lower setting, say downscale from 1080p to 720p as it will make the system's work a little bit lighter and generate lesser heat. Hope it works.
Apr 30, 2010 | Sony PlayStation® 3 (80GB) Console
Downloaded update, next day I got the blinking red light
Mate if you turn your PS3 off when the hard drive is still operating or the power shuts of while playing a game and the PS3 is collecting or writing data to your hard drive, it will most definitely corrupt or even destroy your hard drive it is very common in PC's to.
Hint:
1. Do not shut down your PS3 while it is saving a game or collecting info from the hard drive. Rather quit the game then press your off key with one quick touch and let go of it, it will shut down when it is ready or hold down on the remote's PS button and select switch off system on screen.
2. If you live in a area where the power shuts off for no reason please please get your self a computer UPS(UN-INTERRUPTED POWER SUPPLY).
3. If you replace the hard drive make sure you buy a good quality hard drive like a Western Digital or Seagate.
Sep 06, 2009 | Sony Playstation 3 (PS3) Console
Turn on ps3 screen freezes on welcome screen.
google: rescuetechla
look for my blog page.
Check the 5 most common PS3 problems section and pay attention to # 3.
Hope that helps.
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
System shuts off and turns to red light standby
Hello. You may want to double check your connections and cables. The only time I've ever heard a clicking before a system shut it's self down was when a kid had stuck the battery cover from a TV remote into the disc drive.
Also, if the PS3 keeps acting like that, Sony will repair/replace the unit for free including shipping since it's under a year old. Thanks and good luck!
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Game Saints Row 2 keeps freezing at certain points in the game
maybe you should try different games? see if those different games freeze, if so, then it might be your blu-ray player in your ps3, or your ps3 might be overheating. my games froze at certain points because my ps3 was overheating, just try a few different games
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
Ps3 freezes at startup screen/ green red dots/lines,
Turn off the PS3 with the switch on the back, then turn back on. wait till the light is solid red then hold your finger on the start button for abount 10 seconds until you hear it beep twice.
It will then ask you to connect a controller via the usb cable and press the PS button. Once you do this it will bring up the reset menu.
Unfortunately the only way I found that solves this is a full system restore that wipes the hard drive completely.
You do however retain and data saved online such as COD stats etc and playstation store purchases with your PSN.
Hope this helps??
Dec 13, 2008 | Sony Playstation 3 (PS3) Console
SONY VAIO notebook freezes on xp splash screen every 2-4 mos.
first, ensure your system restore is turned on and make a restore point right now!...assuming you have run a thorough disk check and de-frag. then, trust the system restore. I have used it with success 100% of the 20 or so times I have used it. Next, start using the "Hibernate" power down mode. I have found this to work wonders with third-party driver problems. It seems that once a good startup happens, then freeze it (and continue to get a good startup) with hibernate from then on. Last, check about every month for the quantity of restore points that have taken place automatically by Windows. Sometimes, depending on the size of the hard drive, too many points can begin to encroach on your free space that you want for virtual memory or data. So for example, I see 15 restore points in the last month, I will dlete them all by cancelling system restore. Then I use "clean disk" scandisk and defrag. Then I turn restore back on.
Jun 12, 2007 | Sony VAIO VGN-FE790GN Notebook
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
