Question about Maxtor 80gb 7200rpm ATA 133 IDE HDD p/n MX6L080J4 Hard Drive
HDD problem I have an external HDD by MAXTOR. It suddenly stopped working. Is not the USB not the PC. The light goes on but my PC will not recognise it. When I shake the HDD something rattles. That is new. What can be the problem? Help me plese. Thank you
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
I have a maxtor 500 external hard drive when i plug it to the mains it goes to start up for 10 seconds then dies. Any ideas?
External Hard drives usually draw more current (power) from the PC's USB port and some times even the power being provided by PC's USB port is too less for HDD. In both cases the HDD tries to start but will eventually fail. To cater this you need to buy USB cable with two USB connectors at PC end. Plugging both the connectors to the PC will draw required power from the PC and your HDD will work fine. Also try to connect your HDD to some other PC and see if it works their or not. farhanwaheed.jpg
Jun 20, 2011 | Kitchen Appliances - Others
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Seagat 500GB Portable GO external HDD not recognised on PC
first of all you should try it on deferent pc , if its ok then that leads us to insufficient power provided through usb ports , try using back usb ports not the ON-front, and if the problem still try using dual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.html and if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changed if you cant find a similar one you may buy a new empty cage
Mar 05, 2010 | Computers & Internet
I installed from original CD and my computer running Vista does not find maxtor ll external HD. Is it compatable with Vista? why does it not find the drive?
Start "Device Manager".
Make sure that the USB devices are "ready" and "enabled".
Then, connect the external USB device.
Can you try the Maxtor external device in some *OTHER* notebook?
If it does not work, then the Maxtor device has a problem.
Nov 08, 2009 | Maxtor OneTouch II external hard drive...
I have a maxtor external HDD that has been working fine and all of a sudden has stopped and is now making a clicking noise and my PC will not recognise the HDD. My PC has Windows XP.
Most probably it is going out. Clicking noise is from the platter in the external deive which means it is failing...Sorry but you might have to get a new one.
Try putting the drive in the freezer for about 1 hour and see if it will reconginize it after that...I know it sounds funny but I work on computers all the time....Darren
Let me know how things work out...
Oct 11, 2009 | Office Equipment & Supplies
Maxtor one touch 4 mini suddenly not recognised by any PC
I am sorry to be the bearer of bad news but you are describing a hard disk failure.
Maxtor, Hitachi and IBM disks have unusually high failure rates. I have replaced hundreds of these disks.
I recommend replacing with a Seagate or Western Digital disk.
If this helps please vote for my solution.
Sep 14, 2009 | Maxtor Hard Drive
WD320 GB 2.0 USB external hard drive is not working.
bad driver chip... call the manufacturer.. have the HDD changed...
Jul 09, 2009 | Western Digital Passport 320GB External...
External HDD is not working
You probably have conficker worm because it stops your pc from reading usb's or any external HDD. Or the worm might of infected your HDD since it spreads through usb and internet. Seriously you should get your PC scanned just incase. P.S. Its just a possibility.
Jun 09, 2009 | Maxtor Hard Drive
Maxtor
yes you can download the software by searching it from the net.........
Dec 12, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor One Touch External HDD not being recognized by PC
Try to use other running usb connector or check the HDD inside the external if is plug it will.
Nov 01, 2007 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Computers & Internet Logo
42 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
