Video Game Consoles & Games Logo
Anonymous Posted on Mar 23, 2012
How do i hook up the ps2 to my tv
I cant get sound or pic
Anonymous
Level 2:
Scholar:
  • Expert 55 Answers
  • Posted on Mar 23, 2012
Anonymous
Expert
Level 2:
Scholar:
Answers
55
Questions
0
Helped
33189
Points
178
You can connect your PS2 on tv by using video RCA... connect the fort on at the back of you ps2 and connect the three rca to your tv yellow colored for video, white and red for your audio... tnx
4answers
Connecting to a video game console
Hooking your PS2 Up To your Stereo
Just got a PS2 and trying to hook it up to your TV, stereo or both? Here are instructions to help you get everything working smoothly.
First, some basic cable definitions. These are pretty much standard for ANY system or stereo you ever get, so it's good to learn them.
RED CABLE - right channel for stereo sound (get it - Red Right?)
WHITE CABLE - left channel for stereo sound
YELLOW CABLE - video signal
Your PS2 plays games and plays DVDs. So it is generating signals that go OUT of that box. You want those signals to go IN to your TV. The most simple way to do this is to simply plug them into your TV, if you have no stereo system hooked up and nothing else attached to your TV. Most TVs have stereo left in, stereo right in, and video in. Most in fact have them all color coded with the above colors. So all you do is plug the cables in and turn the TV on. Some TVs have to be set to channel 2 or 3 to know to take the signal in from the Video In line, but your manual would tell you if that was the case. Here is a diagram of the straight connection.
I would really recommend hooking a stereo system into your TV, though. The PS2 has INCREDIBLY stereo sound and you really miss out on a lot if you just have the sound coming out of your TV speakers!! Especially if you play DVDs through your PS2, you want that sound coming out of the stereo system. So in this case you would send the video to your TV, so your TV can show the picture. You then send your audio (sound) to the stereo, so it can play the sound. Most stereo systems have multiple input spots so you can plug in your CD player, your tape player, your record player, etc. So just choose an input spot that isn't taken yet. Here's an image of that connection -
So let's say you don't have a tape player and therefore plug the red cable into "Tape Input R" and plug the white cable into "Tape Input L". To make the sound play, you would now press the "Tape" selection button on your stereo so it played the music coming through the tape channel. Since that's where your PS2 is plugged in, that is the sound that will come out of your speakers.
Cant get ps2 to work; new sony tv, new console, but nothing!
the ps2 you have bought may have a broken cable you can buy new ones
Cable has pic and sound dvd ps2 only has sound no pic. says no signal
try hooking a rca yellow video cord to the adjacent plugs 1 from player to tv video in right next to ps2 input. ps2 is for audio only.
Ps2
The ps2 has a sound threshold, which it cannot surpass. Do you hear any volume at all? If you hear NO volume, verify that your audio visual cable is properly seated in both the TV and the console. If you hear some volume, and its just really quiet, try a different TV.
PS2 showing no video on TV, but I do get the audio
Make sure the male plug which is plugged into the PS2 Console is put in properly so push it in harder This has always happened to me that fixes it!
Hiope this helps - Josh
I can sound no pic i hooked up a ps2 and can hear that sound
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Ok new twist on my ps2 prob...
Hi Bon_64,
I had one a Slim I was repairing tonight that had the same problem.  The motherboard was shot. The processor on the motherboard was cooking hot only seconds after I triied to get it to boot up.
you can get a new motherboard for your PS2 at Repairmyvideogame.com.  If you need someone to replce the motherboard for you email me at [email protected]
Trying to get ps2 to play on new tv..
USE a VCR between the PS2 and the Sylvania TV.  Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4.  Set the VCR channel to Line 1 or Line 2.  This should work. I hope it helps you.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
