Question about Elna 2007 Mechanical Sewing Machine
Elna Carina service
Can any sewing machine repair shop service my Elna Carina?  It is about 20 yr old and I have not have it serviced because it has run so well.  I have done the basic clean with air, alcohol, and oil, but it's time for the real thing.  My zip code is 33511.  Also, what is involved in this service? Thank you for your help. Susan
  • Elna Master
  • 1,117 Answers
Search yellow pages for local sewing machine repair men, then ring them and ask if they can replace the capacitors on your machine. If they start talking knowledgably about the Carina then I'd take it to them. In user groups, these types of technicians are called OSMG (old sewing machine guy) and they are worth their salt. There is also White Sewing Center in USA. website www.whitesewingcenter.com, and they specialise in Swiss Elnas.
Posted on Jun 16, 2011
I just had the same question for servicing of my Elna Carina. I contacted customer support for Elna and received the following e-mail: "Elna machines can be serviced by most authorized Elna dealers. If you need to locate an authorized Elna dealer in your area, please visit our official website at: www.elnausa.com and click on “Dealer Locator” on the top right hand side of the page."
Posted on Aug 19, 2010
4 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Posted on Feb 01, 2008
SOURCE: Elna sewing machine, the timing is out.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Maureen
maureen.reinberger@gmail.com
Posted on Aug 02, 2008
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
Posted on Mar 27, 2010
ELNA CARINA FOOD PEDAL NOT WORKING
Elna Carina has an air electronic foot controller, so you need to firstly check the air line coming from the round air pedal has no holes, is not crimped or squashed under the chair leg. Hold the plug end against your hand or cheek, squeeze the round bulb and see if you can feel a puff of air coming from it. If no, then check the air control black membrane for a hole, ditto the air line hose. You can still buy parts from sewingpartsonline.com for these Elna Carina Electronic 66 Parts . If the line and foot pedal are sound, then the problem lies on the internal actuator which is inside the right side panel of the machine. You can remove this panel by undoing two screws on the side (disconnect from power first!)
The panel will remain connected to the machine body by some cables, you may be able to check out the actuator and see if it is faulty. If its just a tiny hole in it, it might be repairable with a drop of superglue. For parts/service in the USA, Whites Sewing Center is the Swiss Elna specialist, and they may have spare parts in stock.
Feb 09, 2015 | Elna Sewing Machines
I have an Elna Carina SU sewing machine and it will only sew in very small stitches and can not adjust it what is the problem
sounds like the needle bar is gunked up, has it had a service recently? ie the past two years. Has it been used regularly or has it been away for a while and now pulled out and found this problem. All machines if left for a while, internally the oil dries up and that combined with any dust or lint forms a real gunk on the moving parts. Often this results in no swing on the needle bar, ie the machine will only produce a straight stitch, no needle swing. Take it into the shop for a good clean and service.
Dec 26, 2014 | Elna Sewing Machines
Elna carina manual
You may find this at www.diplodocs.com or www.scribed.com free, otherwise you will probably need to buy it from www.sewingpartsonline.com or www.sewing-machine-manuals.com , I think it came as 2 books, Instruction Manual and Sewing Guide.
Mar 23, 2012 | Elna Sewing Machines
Hi, I have an Elna Carina and the flywheel is
I can direct you to a service manual for your machine but it may be something that you need a trained Elna service technician to deal with.
Link is http://www.arizonaexpressionz.com/elna_service/air_elec_carina_elec_SM.pdf
I am more familiar with the SU air electronic where you just hold the outside of the flywheel and turn the inside knob to disengage and rengage the clutch - didn't realise the Carina had a button flywheel release until I looked in the service manual.
Anyway, you could try dismantling the flywheel following the exploded diagram in the service manual if you are technically minded.
Or just take it to a reputable serviceman, I'm a big fan to supporting these guys as their knowledge is invaluable.
Jul 10, 2011 | Elna Sewing Machines
How do I set timing on an Elna Carina 1980 model? I'm refering to the timing between the needle and the rotary hook. The main drive wheel powered by the belt has come loose from the lower horizontal drive...
there is a service manual to download at this website http://www.arizonaexpressionz.com/elna_service/carina_500_service_manual.pdf
but it is written for a trained technician and may assume a certain level of expertise of the reader.
Hope this is of assistance to you.
If you are in the USA you could also contact White Sewing Center, www.whitesewingcenter.com - this gentleman actually trains how to repair sewing machines, and sells many Elna parts, machines and services them too.
Oct 11, 2010 | Elna 2007 Mechanical Sewing Machine
Elna carina how to remove light bulb
There is a small hole on the left side of the top of the machine. Using a thin rod such as the L shaped edge guide that came with the accessories, push down in the hole and the lamp socket (which is spring loaded) will go down to allow you to grasp the bulb. Replace it with a similar long bulb available at any sewing machine repair shop.
Jan 09, 2010 | Elna Sewing Machines
Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Sep 21, 2008 | Elna 8007
Bargain Box
Jan 31, 2008 | Elna 2007 Mechanical Sewing Machine
Elna 2007 Mechanical Sewing Machine Logo
513 people viewed this question
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
