Question about Rockford Fosgate Car Audio & Video
Subwoofer Speaker may need new cone - Rockford Fosgate Car Audio & Video
    Problem Solver:
  • 6 Answers
You cant get a new cone only a new speaker or you car repair it i used super glue on a crack in one of my old subs and it held well
Posted on Nov 08, 2008
Home subwoofer no sound
always 1 speaker per amp output!!! and between red and black only. You can send any signal into a subwoofer. Hi frequencies will be quiet but it's safe. switch a normal speaker for the sub and listen, you should hear a muffled sound. Look for the sub output on the amp... do you need to switch on the sub manually somewhere?
Sep 02, 2014 | Boston Acoustics Audio Players & Recorders
Blown speaker
Your best bet here would be to contact one of these authorized dealers for advice I think.
-Steve
Find Service Center
Nov 14, 2013 | Behringer B1520 Pro Eurolive 15" 2-Way...
My jvc subwoofer inner speaker windings blow up and i m either willing to purchase the whole sub set or jst the inner speaker.the model number is sp-pw 105wd.theserial # 119k0101.
I would suggest to buy the entire cone speaker because the inner windings is harder to find or not available.
The cone speaker part number is: CR160058-01. Try contacting this website to find the cone speaker or you could find a cheaper speaker cone with the same dimensions and wattage.
I can also send you the service manual for this subwoofer.
Nov 27, 2010 | JVC SP-PW100 Subwoofer
How to replace damaged subwoofer? Opened cabinet and found that the woofers' voice coil has burnt and the cone can't move. How to replace it the damaged speaker?
Since the coil is attached to to cone, you are looking at replacing the whole 15" driver (speaker)
To get access to the screws that hold it in place, you'll need to remove the front bezel from the cabinet, then remove the screws around the speaker's rim.
For what it's worth, that driver isn't a subwoofer, it's just a 15" driver. JBL does make 15" and 18" subwoofer drivers, but they aren't the same speaker as what's in this EON. Hopefully that will help you when you're shopping for a replacement driver.
Apr 10, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
My basslink worked great, son blew fuse, replaced, now sounds lik
If the speaker has been overdriven, it may have damaged the cone surround or damaged the speaker coil, causing it to 'rub' inside the magnet. To check for rubbing, you need to move the speaker cone backwards and forwards by hand and listen where the speaker coil/cone goes into the magnet. It should be silent if ok. If you can heara rubbing or grating noise, then the speaker is damaged. If the output driver on the amp is damaged it can give a distorted sound, which could easily happen if it tries to provide too much current.
Nov 04, 2009 | Infinity BassLink II Car Subwoofer
Rubber has been romoved from paper cone
Search for "speaker re-coning" to find a repair shop.
Oct 05, 2009 | Alpine SWX-1242D Car Subwoofer
I need a new voice coil and entire cone and surround replacment for my ma audio 2002 model ma100Xl 10" subwoofer. any Suggestions?
MA does not make a recone kit, and does not repair out-of-warranty equipment.
You have a door stopper i'm afraid.
Thanks for using FixYa!!
Sep 30, 2009 | MA Audio MA 100 XL Car Speaker
When I push my subwoofer cone its work and when i release it stops working. how can i fix this speaker? the make of this is 12'' 1210 Watts Infinity sub.
Looks like a broken copper braid that links the speaker terminal to the cone (from there on it goes to the coil which is underneath the cone).
Check the speaker connection terminals (near the magnet), you will notice that each terminal has a copper braid wire going from that terminal to the speaker cone.
Inspect both braid wires carefully at each end (near the speaker terminal and near the speaker cone), there will either be some damage to the braid at one or more of these four locations or the braid could be actually broken at any of these spots.
The braid can actually be resoldered at the point where it's damaged or broken - this task will require good soldering skills, mainly because this kind of braid wires are difficuld to solder (they are a bit difficult to clean because of their structure and solder won't attach itself well to oxydized copper), but also because some speaker cones are made of plastic which may melt if you overheat it with a soldering iron.
Besides that, when resoldering is being done, only a very short portion of the braid should be wetted with solder because the solder point will become rigid when the solder cools down, and the braid needs to remain very flexible when the speaker operates (if it's too rigid or too short, damage to the speaker cone could occur or the braid could get broken again when the speaker will be playing at a loud volume).
Hope you can have it repaired, it can be done at home, but there are also speaker repair shops where you can get it done (i'm not sure about the prices though).
Anyway, the alternative is to replace the speaker itself.
regards
3rq8 (Triarcuate)
Sep 09, 2009 | Infinity PS-12 Subwoofer
Speaker repair
Contact MMats Pro Audio at 561-842-0600. They can re-cone it for you, or sell you the re-cone kit. If that does not work for you, contact MWA Speaker Parts in Tuscon - 520-647-7193. They can sell you a re-cone kit, or they can direct you to a speaker repair center near you. A third option would be to contact Sundown Audio in Troutman, NC. They may be able to re-cone it for you.
Apr 18, 2009 | Mmats Juggernaut 15'' Car Subwoofer
Radio sound with a noise
Please take out the speaker and inspect it for a torn cone. At times, humidity, amp power or just wear and tear ruins the cone. Then you can replace the speaker or re surface the old speaker with a new cone. That will save you some bucks but may not be as well as buying another speaker. Also please use the same model and Ohms of it. 8 or 16 ohms
Dec 30, 2008 | Elliott's Car Radio Ford-COSF-18808-E Car...
Car Audio & Video Logo
90 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
