Question about ViewSonic VX2025wm 20.1" LCD Monitor
Monitor has lines scrolling down while powere pluggeed into laptop where it is getting it's image from
"power lines" rolling on monitor
  • Roger Haller Oct 27, 2006
    More information:
    The closer the laptop power converter is to the screen the worse the problem.
    It appears perhaps the cabling or the screen is not insulated from outside non contact electrical interference.
    I still very much have the problem and being technical, I can help your technical department isolate and troubleshoot the issue for a fix.
    Roger Haller
One may try attaching RF filters to the video cable. These are usually formed-powdered iron rings or molded flat pieces that enclose over the cable, one on each end near the cable connectors. A plastic cable strap will hold these pieces in place. Or one could search for a video cable with the filters built-in by the manufacturer. Another "Technical" individual.
Posted on Feb 09, 2007
Just bought HDMI to DVI cable to connect my VL193 to my HP laptop - unable to get the monitor to "pick up" the signal - just a blank screen - if I power it on & off, just goes right to power...
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
Aug 24, 2011 | Princeton Digital VL193 19 in. Flat Panel...
Fujitsu Siemens 19 W LCD monitor: no image
Temporarily connect a different monitor to your computer, to see if your video-card is the problem.
Temporarilyh connect your monitor to a different computer (desktop/laptop), to see if your monitor is the problem.
Try a different "data" cable between your monitor and your video-output port.
Jun 12, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
I have rolling lines on my monitor. It is an Acer Al1916w flat screen monitor. It began last night when I pressed the reset key by mistake
Hello, There could be two possibilities. Drivers for Video card are not installed, bad. or a faulty monitor (could be loose inside the computer) or graphics card. Another reason is because the cord that goes to the computer for whatever reason is to close to a power cord or power bar. Have you tried moving it any?
After eliminating all of these things the only thing left is the monitor itself and within the monitor the only component typically capable of producing rolling lines as you describe is the power supply.
I suspect it's the refresh rate in the monitors settings. Try making the refresh rate lower.
Nov 13, 2009 | Computers & Internet
A fine blue line has appeared down the side of the screen any ideas
To determine if you have a provlem with the LCD screen or the video card, connect an external monitor to the laptop's video port and power up the monitor first and then the laptop. The video will divert automatically to the external monitor. If you get a normal Windows image on the monitor then the fault is with the LCD screen, if not then the fault is a faulty video card.
Get back to me with the results of this test.
Jun 28, 2009 | Compaq Presario M2000 Notebook
Rolling Waterfall Effect going up my westinghouse LCD monitor
try moving the monitors.
it could be feedback signal.
also try different leads or without switch.
you will then be able to narrow down the problem to one component.
Feb 25, 2009 | Acer AL1711 17" LCD Monitor
IBM Laptop A31 2652 Garbled video even at initial boot screen
Connect an external monitor to the laptop, power up the monitor first and then bootup the laptop. The Windows image will automatically divert to the external monitor.
If the images is OK then the video card is OK.
From the description of the fault, it indicates that the fault could be a faulty video cable or video connector. Try reseating the video cable/connector on the motherboard.
Get back to me if you still have problems together with any error messages etc.
Jan 25, 2009 | HP Compaq Presario F750US
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Lines on the Screen
2 possibilities video card is damaged and bleeding ac power from the motherboard or the motherboard is damaged from a power spike and is bleeding ac power into the video card(this would be my best guess based on yur description). that is the best i can do on this info you have given I recommend you take it in to a service center for a definitive answer.
Jul 22, 2008 | Acer X221WSD Monitor
Rolling display image
You will need to take your monitor in for repair or buy a new one. I could get into the specifics about WHAT exactly causes this type of failure but bottom line is the same.
Feb 11, 2008 | Apple Studio Display 17" CRT Monitor
ViewSonic VX2025wm 20.1" LCD Monitor Logo
127 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
