Question about Hughes HR10-250 DirecTV / TiVo 200-Hours Video Recorder
HDMI and Component Outputs do not work simultaneously
Have 2 TVs hooked up, one to the HDMI, and one to the component. The HDMI works great, but nothing out of the component. Is this normal? When I disconnect the HDMI cable, the component works fine.
    Genius:
  • 1,199 Answers
Try using a digatal out cable instead of rca cables this should solve the problem!
Posted on Dec 07, 2008
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
I just bought a phillips blu ray and trying to hook it up to my sanyo 50" plasma through a hdmi i get video but no sound the tv says to use the dvi port and audio 3 inputs but the blu ray does not hav
Hello there, the hdmi cable is a great way to get high definition video from a bluray player to a tv, but if the bluray player is part of a surround sound system you will need to get the sound to the tv separately. There is often a red and white audio terminal in the rear of the bluray player, sometimes located next to a yellow terminal, these are known as a component connection as each component (coloured terminal) is separate and operates a separate function, but all 3 connections can be used together to create a SCART equivalent. You may need to connect an 'Audio Component to 3.5mm jack' cable from the white and red terminals to the headphone/line in socket on the tv.
alternatively, as wilth my player, there is a button on the remote which switches the audio source from component, hdmi, SCART, etc, this may be the same for you.
hope this helps.
Mar 12, 2014 | Televison & Video
Formats for dvp-ns70h
selectable 720p/1080i output via HDMI digital interface (separate adapter available for TVs with DVI input)
selectable progressive-scan mode for smoother video with HD-compatible TVs (via the component video output)
optical and coaxial digital outputs for Dolby Digital/DTS /PCM
  • 1 set of audio/video outputs (composite, S-video, 480i/480p component video, and HDMI)
  • plays DVD-Video discs, DVD-Rs & DVD-RWs, and DVD+Rs & DVD+RWs
  • plays CDs, CD-Rs & CD-RWs, and MP3 CDs
  • plays digital picture CDs (JPEG)
  • remote control (multibrand for TVs)
  • 108MHz/12-bit video DAC
  • 192kHz/24-bit audio DAC
Oct 14, 2012 | Sony DVP-NS70H DVD Player
What type of cords do I need to hook up a akia PDP4273m1 to my cable box
Which cable box are you trying to connect to the PDP4273m1? The best choice of cable will depend on the outputs available on the cable box. If your cable box has HDMI (looks like a rectangle with small cutouts on one long side) out, get an HDMI (type A on both sides) video cable and connect it between that port and the TV's HDMI in. (This connection doesn't require an extra audio cable.) If your cable box has a DVI (out, get a DVI to HDMI adapter and the HDMI cable (or a DVI to HDMI cable). Connect the DVI side to the cable box and then the HDMI cable to the TV Then get an RCA audio cable (two male ends on each side, usually red and white). Connect this to the audio out jacks on the cable box and to the DVI audio in ports on the TV.
If you do not have either of those outputs, check for a component video/audio output. Get the component video cable (with 3 RCA plugs on each end - red, blue and green) and an RCA audio cable. Match the colors on each side as you connect the devices.
If those aren't available, the S-video or composite video cables will work. The composite video cable comes with the audio connectors (red, white, yellow RCA plugs). They aren't part of the S-video cable and must be obtained separately. These are limited to standard video (no HD) so they are not the best choices with your tv.
If your cable box has SCART out, you will need an adapter for that. Most provide composite or S-video out. See http://www.svideo.com/scart2.html for one of these. Note: you will need to match the adapter to the CART output or get a converter.
The connections should be from the left side: serial port (RS-232 for service), HDMI, digital audio out (for connecting to a home theater receiver), DVI audio In, two component video and audio in, a composite video/audio in and out and an S-video with audio in. The manual for the PDP4273M1 is available from Retrevo here: http://www.retrevo.com/support/Akai-PDP4273M1-TVs-manual/id/741bh140/t/2/ . You will need to enter a code to download the manual.
i hope this helps. Please add a comment with your cable box make/model/provider if you want more help.
(very few TVs come with the A/V cables these days. Some set-top boxes will come with the composite video cables.)
Jul 15, 2012 | Televison & Video
I have this TV. Had it new since 2005. Has a single HDMI connector. HDMI has honestly never has been used...until now. I am trying to hook a new Apple TV2 to it. The Apple device works on 2 other more...
How old is the HDMI cable? There are different versions of it. 3.5a etc...Purchase new HDMI cable and try it...no reason it shouldn't work. Also, is there component inputs? RED GREEN BLUE? Component is better video quality anyway. HDMI just offers superior 5.1 surround sound whereas component only offers 2 channels. That's the only difference.
Jan 12, 2011 | Televison & Video
A new cable box was connected to my 32" Proscan LCD TV. Now everytime I turn on the television I see the message "HDMI-1 No program information available" I contacted the cable company and...
I know this may be a dumb question but I have to ask because even though the cable company has HD boxes a lot of them still dont have HDMI outputs instead they use the 5 Component cable (red,blue,green,for video and white, red for audio). Not only that most of the cable guys are not the brightest in the world I work in an electronics store for 13 years and cant tell you how many times I went to someone house and it was hooked up wrong. Are you stuck on HDMI-1 or can u chnge the channel by using the tv/video button it may say input as well. Check how its hooked up easy to tell 1 cable HDMI, 5 cables -Component. If it is HDMI check the other hdmi input as most LCD tvs have at least 2. same for component it will say component on screen
Dec 14, 2010 | Proscan Televison & Video
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Hughes HR10-250 DirecTV / TiVo 200-Hours Video Recorder Logo
69 people viewed this question
Top Hughes Televison & Video Experts
jason
Jim London
Jim London
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
