Question about Toshiba 36A43 36" TV
Toshiba 36A43 36" turning off and jumping on certain shows/commercials
In the last two days, the Television began jumping slighty on certain shows and commercials. Especially when there is a commercial that has a lot of writing on it or big words. Now today it shuts down on its own for no reason. Just shuts down and then i have to unplug it and plug it back in to get it back on again. Now when I say jumping it is more like shaking the picture does not move but it becomes shaky . The only thing that recently changed was that I got a upgrade in my satallite box. I have bell express vu and went from a 3100 to a 5900..
    Scholar:
  • 68 Answers
I need to know a bit more. Does to sound give any noises when the picture is jumping? Reason is this would suggest the high voltage breaking down, which could be caused by dust or very high humidity, so check the location of the set. If dust has collected inside you need to clean it out with a long artists brush, but beware if you do not know about high voltage danger. Dust can also cause overheating and shutdown. Is it only the satelite box which causes trouble? If so then you may need to alter (attenuate) the input level of the Video signal. Could you contact the dealers?
Posted on Oct 15, 2006
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
My Aspire 5520-5043 began showing trouble to start: no power ligh
thats mean the charging system is faulty and sometimes there are breakages at the edge of the power cable where the pin is.try another power cable if it shows the same signal then the fault is on the laptop board.
Aug 02, 2010 | Acer Computers & Internet
My wii turns on and the television says that there is no signal but my turns on because y see the power buttons light turn green. Also the wii receives messages because the disc slot turns on then blue...
Make sure you AVI(yellow,red,white)cables are pushed in all the way or you might have it on the wrong channel or you put the AVI cables in a differnt place than last time.
Feb 14, 2010 | Nintendo Wii Console
Wavy line or scrambled picture when l turn the tv on it takes 30mins for the picture to come in clear
If you have a normal picture with lines through it, or if the picture jumps, tears or rolls, you have a Hyper Board that is failing. The last I checked, the Hyper Board is not available from Toshiba and has not been available for a number of years.
I hope this helps,
Skyassoc
Feb 07, 2010 | Toshiba 50H82 50" Rear Projection...
Picture looks like it is jumping
Sounds like a vertical sync issue on the chassis board. However you also mentioned the picture moves left to right or vice versa which would suggest a horizontal sync issue. Either issue is not repairable by the DIY. Sync issues must be isolated using test equipment usually found in repair shops. My suggestion push it down a hill and enjoy the show then go buy that flat screen you almost purchased last week.
Jul 25, 2009 | Toshiba 42H81 42" Rear Projection...
Video fluctuations
Is this happening with commercial dvds or disks that you've burned? If it's happening with commercial disks, I would suggest trying the player on a different TV to see if the same thing happens. If it does, something is wrong with the player.
The warranty on the player is 90 days from the date of purchase. A receipt is required for warranty exchange.
Apr 11, 2009 | Coby DVD-224 DVD Player
TV volume equalizer
Ear-jarring volume discrepancies between television shows and commercials may be a thing of the past if Motley Fool Stock Advisor selection Dolby Labs (NYSE: DLB) persuades TV manufacturers to include its new technology in their sets.
We're all familiar with the phenomenon: We're reclining in our Barcaloungers, calmly watching the late show when a commercial comes on and the volume has suddenly increased 10 decibels, causing us to spill our beer as we jump for the remote control. Dolby says its new Dolby Volume technology will make that rude awakening a thing of the past.
The technology is pretty important for Dolby, because systems incorporating its surround sound technology make the experience that much more jolting when it occurs. It might not be as jarring on your rabbit-ears set in the kitchen, but on that 60-inch plasma screen with five, six, or seven high-def speakers pointed at your cochlea, it can leave your ears ringing.
Dolby will unveil its volume control system at the Consumer Electronics Show Monday in Las Vegas, and the company hopes it will start appearing in television sets by year's end.
The difference in volume occurs because programmers try to compress the sound to boost volume without exceeding the limits the government has set. While most televisions today are equipped with circuits that are designed to stabilize the differences between TV shows and commercials, they are not necessarily effective and can still be problematic if the broadcaster fails to properly operate equipment on its end. Part of the problem: Depending on the type of program a commercial is inserted into, the commercial might actually be broadcast at too low a volume. While viewers might not consider that a problem, advertisers would, so generally, broadcasters transmit the sound all at one level.
Audiovox (Nasdaq: VOXX) recently came out with a device to help minimize sound differences by automatically detecting when a television has gone to commercial and lowering the volume for you. Dolby seems to go one better than this.
First, its technology isn't an external box that needs to be hooked up to the television set. We've already got enough wires crawling from our sets with DVD players, cable boxes, game systems, and whatnot. A sound "equalizer" might just be too much.
Dolby instead offers one chip that would be part of the set's components. (According to some reports, Cirrus Logic (Nasdaq: CRUS) has spoken highly of the development; it may wish to partner with Dolby to put the technology on its chips.) The technology then mimics how the human ear works, and how people perceive changes in loudness because of various factors. Dolby then created formulas to have the technology react to those factors to create a more even experience. It believes it could be applied to MP3 technology as well.
Perhaps another area where it should be investigated is cell phones. Despite advances there, sound quality has never been all that good, but Q Sound Labs (Nasdaq: QSND), another surround-sound developer, is using its MobileQ technology to provide a surround sound experience on close-proximity speakers and headsets. With advertising moving to mobile phones, quashing loud commercials before they begin could be a big seller.
Let's hope Dolby's technology proves popular, if only so that another drop of beer will never be spilled while jumping to turn down an annoying commercial.
Want to see what other high-decibel recommendations have been made in Stock Advisor ? A 30-day guest pass gives you full access to all the market-beating selections.
Fool contributor Rich Duprey owns shares of Dolby but does not own any of the other stocks mentioned in this article. You can see his holdings here. The Motley Fool has a disclosure policy.
May 12, 2008 | Transparent French TV Commercials, Volume...
Volume suddenly turned down during commercial
shut off the all BBE and surround and the AL sound page 27 of the manual.
Feb 22, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Toshiba dvd Video player & vcr SD-V396SU2
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Anoyed
Nov 29, 2007 | Toshiba SD-V394 DVD Player/VCR
Toshiba 42H81 - Constant jumping picture on scren
it needs the hyper module replaced might as well have em do the stk packs too its too old to be a lemon the part that was replaced was not new it was in someone elses tv and had problems there too the trick is to find someone that will fix it so it lasts
Dec 05, 2006 | Toshiba 42H81 42" Rear Projection...
Toshiba 36A43 36" TV Logo
122 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
