Where are the fuses located or the ICs?
You have come to the right person:
all parts in this model for the convergence are located on middle board.
If set comes on and shuts off (green power light goes out) do the self check: press and hold (you may know or have done this) both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
That is short protect and a 98% chance one or both (usually one) of the two pico fuses that protect the convergence circuit have blown.
I will add some photos here one of the single IC this set uses for this, one of the protect resistors in front and to one side of it, and one showing the pico fuses (ones for the chip are circled)
A note= I have fixed a lot of these and have composed instructions which are based on doing it---tell you everything you will need and how to do the repair from start to finish--step by step.
I will not post them here as other experts will copy them and I spent some real time composing them.
If you want they are free--provide me a email address and I will forward them to you for free.
I have fixed almost a thousand of these sets (Mitsubishi) with this problem.
Copy and save the photos and let me know (you can post a comment here) if you have questions or want the instructions.
SD TECH
the photo for the fuses will not load---on middle board to left and towards the rear--green and location numbers 9fao4 and 05--both are marked 5 amp,.
This is awesome!
Thanks so much for the solution SD Tech, I was searching around teh interwebs for something like this because my buddy is having the same issue. Cheers bud.
if you want the instructions get me a email and i will forward them to you.
my TV has the same problem, would love to have the information to fix it, how do i find your email?
Fred: post a question attention to me with your email and what you need and I will forward it---have in the past had over 70 people respond as you did--do not want to have to copy and email instructions 70 times--will not post here as competition will copy and use as their own.
SD TECH
My email is [email protected], thanks.
Please send instructions to [email protected]
please send instructions to [email protected] thanks,,,,,
Do you still have the instructions available to send out? if so, can you send to robert_h56 at yahoo dot com ?
SOURCE: Mitsu WS-65909 COMES ON AND TURN OFF IMMEDIATLY, ERROR CODE 2-2
Two blink code on this set means Usually one of the two pico fuses that protect the STK-393-110 CONVERGENCE IC is blown--the fuses will need to be tested and the chip and them replaced--
If you have enough skill I have step by step start to finish instructions for this repair in this set---set detects one of the voltages to the Chip is not there and shuts down instantly. I have photos of the chip, fuses and protect resistors this set uses also.
If you want the instructions for free give me a email and I will send them to you for free--if you are able to do this repair yourself you will save a lot of money--you can buy the chip on Ebay for about 14 dollars plus shipping and the same seller sells the pico fuses..............
If you want to attempt this give me a vote here--If you are not able to do it yourself I have suggestions for you about getting the set fixed--I have done hundreds of these sets!
Just reply to this post here.
Let me know what you want to do, I am here to help people
SD TECH
Testimonial: "This is what I thought from reading your other posts, please send me instructions. [email protected] Thanks"
SOURCE: I've a mitsubishi ws-65909 and
Hi my name is Roety,
I can help you with your issue ,
If you can solder you can replace the Convergence ICs
A repairman would charge about $400 to do it for you
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: Mistubishi ws-65909 will not come on
Yes, you need self diagnosis test first goto www.ctechnicians.com and read
SOURCE: Mitsubishi WS 55819 with a convergence
CEM-NO, BOTH ICS' WORK ALL 3 CRT YOKES.YOU EITHER NEED TO REALIGN THE RED IN FACTORY CONVERGENCE MODE OR YOU HAVE A RESISTOR THAT HAS FAILED.THE LATTER YOU MAY ACTUALLY BE ABLE TO SEE IF YOU LOOK CLOSELY.OH, ALWAYS DOUBLE CK. YOUR SOLDER CONNCETIONS.GOOD LUCK. JOE TV
SOURCE: I have a mitsubishi ws-65909 - flashing 2,2. Can
I have this information but it is too large to post here.
Let me know by rating this solution and I will find a way to give you the instructions.
SD TECH
Hi SD Tech,
One of the two fuses is open. I noticed 5 0r 6 ribbon cables going from this pcb to the adjacent pcb's. They look rather frail, and I tried gently lifting them to disconnect. Is there a tool for this...maybe something from Radio Shack?
best way to do that is explained in those instructions I have--very easy to damage the lift up connecters and the middle board needs to be removed to do the repair.
Give me a email address and I will send them---I am not phishing just will not post them here to be stolen by other experts here to use who do not know how to do the repair---that simple.
Please send the instructions, [email protected]
my email is [email protected] i need help in fixing convergence problem with the 65909 misitubuchi.... can u send me instruction with picture and what i would need to fix it ....thank you
HI We are having the same convergence problem issues with the 65909, my husband is going to take a look in there. But pictures and some better instructions would really help us. Can you give us some step by step at [email protected] We would really appreciate it. We don't have any expertise in looking at TVs. Thanks, Debi
Please send instructions to [email protected]. I'm shooting for one more year out of this unit. Thanks
