Question about Canon NP 6050 Copier
How to read the meter on Cannon Copier
I have a Canon IR2200. How do I read the meter on it? It says for the counter check 00202718. Is that a total amount of copies made on the whole machine's life? Thanks for your help.
  • Canon Expert
  • 1,326 Answers
Yes, that is the correct counter of the copier. If you are doubting it, you can look at the bottom right of that display and confirm that the serial number is the same as on the back cover of the copier and also, it well tell you the model of the copier aswell. It is kind of hard to fake the meter or change it to a lower amount. To do it you need to change 3 PCB's from another copier & it is more work to bother with.
Posted on Nov 07, 2008
Where is the meter read button on the canon 1025?
hi sir, nothing counter / read meter button on this copier, and you can see at the mini LCD only.
to see reading meter you press the star button (*) than you press (>) or (<) button to find a counter than press (ok) button.
good luck
Jun 24, 2011 | Canon imageRUNNER 1630 Copier
How do I take the meter reading on the Canon Image Runner IR2200
on the operation/control panel there is a small switch indicating 123. press it and saw ur counter reading of m/c.
Jul 05, 2010 | Canon imageRUNNER 2200
I want to scan a paper using the cannon ir2200 super g3
Do you mean scan to your computer?
If so first you need to make sure it's networked. When you press the counter check button do you see IR2200(IR2200N)? Also is there an ethernet NIC in your copier?
If your copier is not networked you will need to get a tech to come and install a NIC and load the necessary firmware.
Then if not already setup on your network:
Do you have the Network Guide?
Go to page 2-11 and follow the instructions there.
You can click the DHCP icon and hopefully you'll get an IP address etc. (you may have to restart using switch on right hand side of copier to turn off, wait a while then turn back on). Once you have an IP address click on the DHCP icon again to make sure it's not filled in with black and save settings.
IP address must be in same range as other devices on your network e.g 192.168.1.x or 192.168.0.x (only specify a number for x between 1 and 254, must not be used by another device). Subnet mask must be same as for other devices. It's probably 255.255.255.0 Once setup on your network, download Canon Network ScanGear 2.21 (don't get the colour version) and follow the instructions in the manual included with the download.
Dec 17, 2009 | Cannon i70 Printer
How do I get to the black toner reading on a Sharp AR-M257 copier
Hold down the Copy button and you should see a readout for the total copies printed from the copier and the percentage of toner left in the unit.
Aug 28, 2009 | Sharp AL 800 Copier
Myprint totals say zero.
Press the counter check button. What counters do you see. There can be up to 6 different ones I believe. What counter numbers do you see e.g. 101: Total 1
Counters to display can be set using Service Mode. Press Additional Functions > 2,8 > Additional Functions.
Copier > Option > User > COUNTER1,COUNTER2,COUNTER3,COUNTER4,COUNTER5,COUNTER6
Default's are COUNTER1: 101, COUNTER2: 103, COUNTER3: 201, COUNTER4: 203. COUNTER5, COUNTER6 none.
You could try entering those counters.
The counters could have been reset. It is apparently possible but certainly not advisable to do so without permission from Canon.
Jul 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon NP 6050 Copier - number of copies
I would say that is not the correct meter. The meter is only 6 digits long, maybe 7 it's been awhile scine I looked at one. You probly have a meter of 0136012. There is only one hard counter / meter in the copier. It's not even the serial number?? Good luck
Apr 30, 2008 | Canon NP 6050 Copier
Meter reading on Canon PC 1061
How do you fix the roller of a canon pc 1061 copier? Can I get the owner's manual online?
Feb 27, 2008 | Canon PC1061 Copier
Canon NP 6050 Copier Logo
2,088 people viewed this question
old marine
old marine
