How do i get my lexmark x1130 all in one scanner to work again please,each time i try to scan,it sounds like its stuck on some thing so,and this something stops it from scanning can anyone help me fix the problem please.
jay-jay-g
  • 48 Answers
SOURCE: Scanner Problem Epson Stylus CX4800
Try to clean the scanner glass with a dry cloth...
Try scanning afterwards...if the same issue occurs...
Try to uninstall and reinstall the scanner from your computer..
If you have windows...
Go to add or remove programs and uninstall "epson scan"
Posted on Apr 10, 2008
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
I had the same problem with a new Canon MP970. Printed ok, but couldn't communicate with the scanner - error 2,155,0.
Canon phone support didn't help, and suggested it was a firewall problem. I uninstalled, and re-installed, turning off firewall, virus software, and everything. No luck. Tried several USB cables, no luck.
Then I uninstalled again - as well as a couple of old drivers and software associated with two now deceased printer/scanners.
This time I plugged the (same) USB in and turned on the device, using Windows' own hardware install wizard.
Now it works fine (at least for now... touch wood).
So - the problem might be either conflict with other printer/scanner devices installed, or with Canon's installation software.
Posted on Aug 02, 2008
mickspaceNET
  • 115 Answers
SOURCE: Lexmark x2250 all-in-one center download
this all in one comes with software, when you bush that button it sends a signal to the PC which should open it up and scan..
this is a link to lexmark, after you have selected the proper operating system select the software, and install
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:436:0:0
Posted on Oct 24, 2008
madguy1089
  • 21 Answers
SOURCE: i have a lexmark x3350 and the scanner wont scan
Alot of the X3350 all in ones have there scanners go bad if you still have a warranty for this printer then call Lexmark if not then you can go out and buy one for like $85.
Posted on Apr 28, 2009
I cant find tha drive to get print whit Lexmark X1130
Please visit the Lexmark website to download and install the Lexmark X1130 Printer Driver on your computer. Select your operating system > download > execute the file. Follow the instructions on your computer screen.
Sep 12, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
Have a Lexmark X5650 printer/scanner that won't scan at present. Trying to scan my work (comic book artist) to a memory chip then into photoshop on the laptop for tweaks before turning them in and the...
ok. if its making a grinding noise its the belt slipping. you may not have the print cartridges installed properly. kit could also be the scanner belt that may be slipping. Basically if its not the print cartridges then the scanner is stuffed. Unless you are handy and are prepared to pull thing apart to get to the scanner belt I'd say it has gone to god.
Jan 17, 2011 | Lexmark Office Equipment & Supplies
Problem with scanner lexmark x5470
Have you tried scanning through the windows built in Software? Does it do the same thing?
Aug 23, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x2500 scanning
try re-insatalling gthe scanner driver again...
Jun 20, 2008 | Lexmark X2500 All-In-One Printer
Scanner - Scanning Bar Became Stuck
if the scanner bar is stuck in the center then U hav to call Lexmark tech support at 8003324120 & have them chk the warranty of the printer.. if its in warranty it can be replaced
May 20, 2008 | Lexmark X1270 All-In-One InkJet Printer
Scanner problems
try to change cableof scanner to pc.
Apr 01, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Scanner not working right
have you checked to see if there is anything stuck in the scanner area thats the same thing that happened to mine and there was a paper clip stuck in where the runners are for my scanner
Mar 02, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x6150 wont scan
Sounds like your laptop isn't talking to your scanner. These scanners only work if it has access to a computer to store the scanned image. Check if your USB drivers are installed. Most times you can go to "Device Drivers" in Control Panel (Under the "System" icon) and right click USB to update drivers on the net. Depends how old your laptop is too. If that isn't the problem, try installing the drivers again, or search the net for newer versions.(Usually at the Lexmark site). But at the end of the day, you won't be able to scan till your laptop can recognize your Lexmark printer!!!!
Feb 14, 2008 | Lexmark X6150 All-In-One InkJet Printer
Lexmark x6170 will not scan
Try resetting you machines by turning off and unplug, reverse steps and try again. If no go, repost and we will try again. Cheers lilacgerry xxx
Jan 09, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X1270 scanner problem
The only way i can get my Lexmark X1270 to scan is to use the Windows Vista "Windows Photo gallery" to scan :
Start > All Programs > Windows photo Gallery > File > Import from Camera or scanner > select the scanner > save scanned file to your computer
This is the only way I have been able to use the scanner on my lexmark X1270,hope it works for you too.Be lucky.
FossyBear
Dec 11, 2007 | Lexmark X1270 All-In-One InkJet Printer
jasbo
jasbo
