Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
My Hotpoint Aquarius 1100 (washer dryer) has started to making quite a loud grinding noise when the drum is turning. This noise occurs whether you are using the washer or the dryer. Any ideas what it could be? The machine is about four years old Thanks Claire
  • Anonymous Mar 13, 2014
    aquarius washer dryer lights flashing and will not start
  • Anonymous Mar 22, 2014
    The drum is making a loud noise when it spins
    Problem Solver:
  • 11 Answers
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Posted on Feb 18, 2007
Sound of metal grinding when drum is turning
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 25, 2011 | Hotpoint Aquarius WD640 Front Load...
When washer is on spin mode there is a very loud grinding noise and when i check the inside to see if anything left in when wash has finish i turn the drum and the grinding noise is there.Please can anyone...
Take the backplate off the machine and take out the heating element which looks like a long oval and has three wires to it you can then see inside the drum to see if anything is in there
Feb 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Spin cycle
Most likely your drum bearings are worn out. This is a major repair.
You may be better off replacing the machine.
Ash
Oct 22, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint aquarius 1100 washer dryer wd51 was making a grinding noise we turned it off and a under wire from a bra was sticking through a hole in the drum pulled it out and it is complete but now...
The bra wire bears no relation to your present problem.
Remove top cover, screws at rear, and push top cover back.
See if the belt is still on, if it is, then select final spin and see if the motor and drum go round, if it does not, then the brushes in the motor probably need replacing.
Unplug washer, and disconnect the motor. you will find the brushes at the motor plug end, depress plastic lugs, and slide brushes out, if they are less than 5mm long, then replace them
If it is the belt that has come off, you will have to remove the rear panel to refit it.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Loud grinding noise when dryer is on aslo blew fuse last night
sounds like bearings in your ctd40
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Dec 09, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
760 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
