Nec multisync lcd 2080ux no raster no power indicator light.
I have a nec multisync lcd 2080ux monitor. Cables are tight, covered the basics. No raster, No power indicator.
  • chefdave136 Dec 02, 2008
    My ribbon cable connecting the board to the monitor turned out to be very crumbley. It fell apart when I touched it. Thanks for the tip though.
    New Friend:
  • 99 Answers
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
Posted on Nov 08, 2008
NEC Multisync LCD 2080UX has a strip that appears on screen after 20 mins use.
Might be from overheating, monitors do overheat sometimes. I had the same issue happening to one of my old monitors and it wasn't fixable unfortunately. I had to replace it and get a new one.
Nov 05, 2013 | NEC MultiSync LCD1810X 18.1" LCD Monitor
Power light stay green, but no picture.
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 16, 2010 | NEC-Mitsubishi MultiSync 2080UX (Black)...
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
NEC 2080 UX - power light flickers - pics of appears broken caps?
you can change these, you need some soldering skills. the monitor is 3 colour sets. so they have same components on the 3 colours. so you take all is leaking out clean the liquid (sulfuric Acid), and replace with a new ones. you find the components in your local electronics stores.
Feb 09, 2010 | NEC-Mitsubishi MultiSync 2080UX (Black)...
My NEC Multisync LCD 2080ux + has developed a weak display which makes text harder to read. I have adjusted the ATI Radion 9600 graphics card with no success. Any ideas?
One thing that will affect how clear the display is if the monitors resolution is set to the wrong value. your monitor must be set at at its native resolution of 1600x1200. Any other value will result in a degraded display.
Nov 05, 2009 | NEC LCD2080UX (Black) 20.10" LCD Monitor
NEC MultiSync LCD2060NX does not power up
Not user servicable and with the low prices of new monitors - not worth the cost of the part.
Oct 29, 2009 | NEC MultiSync LCD2060NX (Bezel) 20" LCD...
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 02, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
NEC MultiSync FE2111SB 22in monitor problem
a blinking green light usually indicates no video signal. check your cables, and if you have another computer, try it on that. otherwise, carefully check your vga signal cable, and the connections on the neck board [where the crt plugs into]
Aug 11, 2008 | NEC MultiSync FE2111SB 22" CRT Monitor
Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Jun 02, 2008 | NEC MultiSync 1550V 15" LCD Monitor
Computers & Internet Logo
688 people viewed this question
David Payne
David Payne
