Question about Minolta Di151F All-In-One Laser Printer
How to change from metric back to inches
I was making copies when a page got jammed and I managed to get it out. When I continued making copies I started getting the Code H2 which means the machine has changed from inches to metric. Help me reset the machine back to its original stetting.
  • Anonymous Nov 08, 2007
    minolta di151 how do you set from metric to inches?
  • gary1960 Nov 08, 2007
  • Minolta Master
  • 6,830 Answers
H-2 errors are displayed when trying to change paper size in the U-7 function area. Also, the setting shows only two paper sizes instead of three.SolutionCAUSE: The machine is set to the wrong marketing area.
SOLUTION: Set the machine to the proper marketing area. USA=MC
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 26, 2015
5 Suggested Answers
SOURCE:
  • 56 Answers
SOURCE: EP4000 Back to back copying paper jams
THE INK MAY NOT BE TOTAL DRY WHEN MAKING BACK TO BACK COPIES, SOMETIME YOU NEED TO LET THE PAPER TONER DRY, LET THE PAPER COOL OFF BEFORE PUTING IT THREW THE MACHINE AGAIN, AND I KNOW ITS A PAIN IN THE BACK SIDE.
TRY IT
CANDYMANGANDY
Posted on Jan 28, 2009
goalie39
  • 472 Answers
SOURCE: single copy out of double original w/o using paper feeder
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
Posted on Apr 14, 2009
firecontrol7
  • 6830 Answers
SOURCE: Machine makes a loud wheezing noise just before
Mite have a broken gear in the fusing section (Hot Part) unplug machine and open **** shell and look to the left (if standing in front of machine) the left side rear is the fusing drive section check all gears also remove image unit and check gears
Posted on Aug 02, 2009
firecontrol7
  • 6830 Answers
SOURCE: sir i face problem in di 650,i place original
Sir,
Do you have the paper selection in AUTO? Mite you also check your defaults settings
Posted on Feb 21, 2010
Convert 6.490'' into inches
with a double quote ( " ) after the 6.49 it is already inches? Roughly six and a half inches.
Conversion of inch to centimeter (cm)
www.calculconversion.com/conversion-inch-cm.html
Convert or calculate inch to cm or cm to inch. Free online converter of inches and centimeters (cm).
Millimeters to Inches conversion ' mm to inches - Metric Conversion
www.metric-conversions.org > ... > Length Converter > Millimeters Conversion Bookmark Page inches to mm (Swap Units) Millimeters to Inches table - Click here for table options. ... The millimetre is a unit of length in the metric system, equivalent to one thousandth of a metre (the SI base unit of length).
convert 6 490 into inches Google Search
Mar 19, 2017 | Office Equipment & Supplies
How do I fix my Utax CD 1315 every time it makes a copy J40 appears in the window and won't make anymore copies
J40 is a paper jam might be a pickup roller check complete paper path might also be a hung exit sensor
Sep 16, 2016 | Office Equipment & Supplies
Error light flashes screen reads caution machine trouble than change to service call 101 h
Scanner motor malfunction, check the scanner lock switch, normal use when moving the machine so scanner does not break, or you have a bad scanner, which is located under the big glass with the very bright light that comes on when you scan or make a copy..
As for the paper check to ensure you have the correct media selected not metric but inch, check your driver setting also inch not mretric no A3 or A4 that metric
May 20, 2014 | Konica Minolta magicolor 2490MF Laser...
The out copied paper is not fully copied
First turn off at the wall outlet and count to 20 and plug back in to reset.
If that doesn't work, it sounds like there is a zoom feature and it is set to copy at 110%, making it too big to fit on the A4 paper and it is continuing on Page 2.
Jul 29, 2017 | Canon NP 6050 Copier
Cannon d1320 false paper jam
this happens due to overheating of the fuser unit.try resetting it
Jan 25, 2014 | Canon Imageclass D1320, Copy, Print, Scan...
How to convert from feet and inches to metric?
Click the screen to access main menu this should bring up the ability to click change preferences and then in that menu you should be able to scroll through and find the option to change from feet and inches to metric.
Mar 02, 2011 | Tomtom GO 750 LIVE GPS Receiver
Blank print top 1 inch has print Toner cartidge has been changed
I need more information. If you make 20 copies do you still notice the problem or only when you receive a fax. What is your copy count (press life 1). Does it jam or make noises. At first glance I would say phone line problem. .
May 26, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Xerox copycentre c20 paper jam in 2 how do i get it out please
Unplug the machine, open the right door. Get a phillips screwdriver.
Look on the upper portion of the paper path, you will see an assembly with yellow waning stickers that say HOT. There are 4 silver screws on that fuser assembly. Remove those screws, and unplug the white connector. Pull back toward yourself to remove the fuser.
Lay it down and remove 2 silver phillips screws , it will open up and you can remove the paper. Make sure the machine has been off for a half an hour or so, It is hot. Take a good look at the black aluminum coated roller on top. See if it looks smooth and clean, If it has a lot of toner built up on it, you will have to repalce the fuser or it will continue to jam and give you ghost ( light reprinted) images up and down your page.
Also the M20 does not handle large black ares on a page such as a picture or magasing cover being copied. Largs solid areas tend to stick to that heat roller. If you do copy a photo, try and allow about 2 inches on the top of white. Just move your original down on the glass about 2 inches from the edge. 2 inches to tie right of the edge of the glass.
Jan 18, 2009 | Xerox CopyCentre C20 Black and White...
Minolta Di151F All-In-One Laser Printer Logo
47 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
